View Full Version : Lipo count for BEC for Swordfish 120
BHChieftain
11-05-2010, 09:02 PM
Hi,
How many lipos can the BEC for a Swordfish 120 handle?
On a Castle Hydra 240 I think it is only 3S...
Chief
Rumdog
11-05-2010, 09:09 PM
Just run a RX pack to be safe, and disconnect it. It's not worth the risk.
keithbradley
11-05-2010, 09:17 PM
Yeah, what he said.
You can run 4s on it, actually they can run on 6s, but you lessen the strain on the ESC by running an RX pack. I have ran the BEC on one before because of the lighter load I was running on it and I had problems with it so I ended up cutting the wire at the lake and running an RX pack.
driftah
11-05-2010, 09:26 PM
bec and rx pack on anything over 3s or 4s for me on all speedos cheap or expensive,cheap insurance kinda
BHChieftain
11-05-2010, 10:24 PM
I run an external UBEC (from the main packs) on my other boat-- I'll do the same with this ESC.
Thanks,
jq
BakedMopar
11-05-2010, 10:57 PM
I don't see all the fuss with running an extra UBEC. Why run a seperate one when one is already built into it. With the exception of castless hydra series most use a switching style BEC not linear like castle's. Maybe it was a good idea with older (linear) technology but not so much with the switching types. I run my internal BEC with all my boats up to 6s. I had one failure on a T180 while using the programming card go figure. That esc does NOT run any cooler than it did with its internal BEC.
If you insist use a seperate rx pack so you get clean power.
BHChieftain
11-06-2010, 11:02 AM
Let me rephrase the question then-- has anyone had a Swordfish 120 BEC fail?
Chief
BakedMopar
11-06-2010, 01:59 PM
No personally.
Alexgar
11-06-2010, 02:00 PM
on 6s ,no mine runs fine
keithbradley
11-06-2010, 02:05 PM
Yeah, what he said.
:tiphat:
Ronbo
11-06-2010, 08:50 PM
Im running 4s and BEC internal on the 120. so far so good. If it fails, then Ill put on a castle.
We run BEC on small electric helis, running 4-5 servos, digital and a gyro, so 1 servo plus rx shouldnt be a big deal unless the internal BEC is crap.
anyone have different on swordfish? Im going to try the internal on my turnigy 120 as well.
