View Full Version : Genesis Stingers!
FighterCat57
11-05-2010, 09:50 AM
OK, prototypes are en-route!
Still working on the 3/16" version, but worst case can drill/insert a Speedmaster bushing.
RCKong
11-05-2010, 10:16 AM
FC, very interested in these, they look tight.
RCK
Alfa Spirit
11-05-2010, 10:24 AM
Use an adapter 4mm => 3/16"
FighterCat57
11-05-2010, 10:29 AM
Yep. K&S #128 brass works well as a shim to use 3/16 props.
The hard part is convincing a foreign mfr that imperial fractional measurements are a "standard" worth pursuing.
Still working on it though. :thumbup1:
If we do end up with 4mm, I'll stock up on extra 4mm supplies to fully support 4mm shafts.
battlefury
11-05-2010, 10:51 AM
HI FC, do u have a estimated time for the pre orders? :popcorn2:
FighterCat57
11-05-2010, 10:52 AM
I'm hoping within the month, but have a 12/1 pre-order date setup.
battlefury
11-05-2010, 10:54 AM
this is really great news. God bless OSE. Thank god for you!
FighterCat57
11-09-2010, 08:33 AM
OK, the order is IN!
Just waiting on the factory now. I have two versions coming. 4mm and 3/16.
Due to the captive nature of the 4mm shaft, it is still a recommended solution for novice/intermediate boaters. 4mm captive 2 piece shafts are much more forgiving for loose couplers than losing an entire cable/dog/prop/nut setup with the 3/16 non-captive stingers.
Again, the 4mm stingers have been machined with extra material that will allow the bushings to be removed and drilled for 3/16" bushing, such as a Speedmaster.
Officially, the clock is ticking! :beerchug:
Please sign me up for a pair of the 3/16th.
Thanks,
Ray
FighterCat57
11-10-2010, 01:08 PM
Thanks,
Ray
Pre-orders start 12/1. BUT, I'll put you on the list, cuz I owe ya one. :thumbup1:
Here's a look at the prototype on the Genesis hull;
I really dig the blue colour on that hull... :thumbup1:
FighterCat57
11-10-2010, 03:12 PM
That's Bahama Blue and isn't clear coated yet in the photos. Just put the final coat on a few minutes ago. That's the prototype hull. :spy:
Thank you Sir!
Ray
Jacked1
11-10-2010, 06:07 PM
Sounds like it would be sweet if you could find someone with a lathe that could make some 3/16 stainless steal prop safts for those that were staggered like the 4mm ones so you wouldn't have the problem of losing the prop and everything if the coupler loosens up.
I have heard about loosing a prop shaft many times. However, in running boats for 15 years I have yet to loose one.
Ray
Jacked1
11-10-2010, 08:19 PM
Ray
I never have either and got my first one about 11 years ago, But I do hear about a lot of people loosing stuff as well! :confused2: *knock on wood* :Praying:
LOL
FighterCat57
11-24-2010, 12:03 PM
We sent the first batch back, they weren't the right size. They came in 4mm.
They are currently re-working them as 3/16".
I also increased the overall length to 110mm for some extra clearance on the transom.
Will keep this thread updated. As well as the FC site; https://sites.google.com/site/fightercat57/what-s-new
FighterCat57
11-29-2010, 02:12 AM
OK, Just got confirmation they are in production and will be shipped in two weeks. Please feel free to pre-order them; https://sites.google.com/site/fightercat57/hardware/100mm-stingers-4mm
Worse case they'll be at your door 1/1/11. Best case 12/15.
FighterCat57
12-02-2010, 06:15 AM
Please pre-order them now if you can. I'm running out of $$ stocking up on parts. Have to get some sales going to pay for new orders. I had to order 100 of these and they upped the cost by 200% after the last order/mistake, so now I'm behind the 8 ball.
Pre-orders are 100% refundable at any time for any reason. :beerchug:
LarrysDrifter
12-02-2010, 12:11 PM
Mine are ordered.waiting anxiously.
FighterCat57
12-02-2010, 12:42 PM
You are on the top of the list Larry! :beerchug:
As of now, they should be shipping from the Factory somewhere between the 6th and 10th. I'll keep this thread updated with the latest information. It's been a long time coming. I started this request in September! :eek:
Jacked1
12-02-2010, 04:34 PM
Are the 3/16 one's prop shaft made to accept a square or round flex shafts?
FighterCat57
12-02-2010, 04:42 PM
Both. To use a 1 piece cable, simply remove the hard prop shaft and insert the cable. Will also accept 3/16 078 wire drives.
Good stuff. Works both ways. :beerchug:
Remember the value of a two piece system is not losing the cable/hard prop shaft if the coupler comes loose or cable breaks.
Jacked1
12-02-2010, 05:31 PM
Cool! Are the cables included? I am guessing they are since there are L and R designations. And thanks again Ben! U seriously much have the best customer service of anyone ever!
FighterCat57
12-02-2010, 05:44 PM
I'll have a set with cables once I get it all sorted out. It'll be 4mm (.150) to 3/16".
Keeping my fingers crossed that the new batch is correct. :Praying:
Jacked1
12-02-2010, 07:28 PM
haha okay sweet! I was worried there wouldn't be cables for left and right rotation, I think i am gonna order some pretty soon!
LarrysDrifter
12-02-2010, 08:09 PM
Sweet!!Cant wait!!:thumbup:
FighterCat57
12-02-2010, 09:20 PM
Ah, OK, Just got a firm date of 12/20.
Apparently they have to make a new aluminum mold for the extended length of the stinger which is pretty expensive. :eek:
I'm laying out close to $5k to have these made, so...
PLEASE, PLEASE, PLEASE pre-order these stingers!
(Just like Larry did. Thanks Larry! )
Tell your friends. Order extra! Tip your waiter! :smile:
