View Full Version : MG ESC Dead on 5s
POWERS
11-04-2010, 09:45 PM
I finally got the MG set for running on 5s and did the rudder stand-off mod and got her to the pond. She flew like a bat out of hell for a bout 4 full out runs then she died. After about 20 min of fishing I got her back in and the ESC temp was still 160F.
Anyone know the warranty on these things? Or am I better off looking for a beefier esc? Obviously the latter would be better for the boat, but if I can get it replaced I can throw it on ebay to help pay for a better one.
jac4412
11-04-2010, 10:04 PM
Did you disconnect the BEC....
jac4412
11-04-2010, 10:05 PM
And I don't think the warranty will cover modifications... you most likely blew the esc. You should look into a better one (120a) if youre going to run 5s and an external battery pack
POWERS
11-04-2010, 10:09 PM
I did disable the bec and was using a receiver pack.
jac4412
11-04-2010, 10:10 PM
Interesting... what prop were you using? I don't think anyone has reported that high of a temperature running 5s
Diesel6401
11-04-2010, 10:15 PM
Can you provide some more info
Prop used:
Run time:
Batts used:
Did you change ALL the connectors over to at least 5.5mm?
jac4412
11-04-2010, 10:16 PM
And how did it run (what were the water conditions like)? Did you notice the boat stressed?
POWERS
11-04-2010, 10:30 PM
Used a x642 prop.
Run time was probably less than 2 minutes.
Used a 2s 5250mah and a 3s 5250mah 60c MaxAmps Lipos
Only connectors in the boat changed where the batter connectors and they were traxxas
The boat ran great, i was getting used to the speed on 4s and this was definitely a huge improvement. The water was smooth as glass.
Rumdog
11-04-2010, 10:44 PM
It's a 4s esc.
Diesel6401
Used a x642 prop.
I think you just answered your question. You should also have change the 3 sets of connectors that connect to motor and esc with at least 5.5mm bullet. The stock 3.5mm are just to small and tend to heat and de-solder which leads to issues and possible failures. All of this is JMO of course, but that is why I asked the question. I ran 5s all day same prop no issues temps not a problem with that motor/esc combo. I have switched to a different PB motor though. I run the Stileto 1800kv motor with the MG esc which is only 45amps. The stileto comes with a 60amp esc. So far no issues, but if a failure occurs it's 100% my fault for pushing the limits of the esc. I do have telemetry setup on my boat so I get a live reading of esc temps on my radio, I also have the radios alarm set to 135F if the temp reachs that point an alarm goes telling me to stop.
POWERS
11-04-2010, 10:46 PM
I figured it had to be something I didn't do right. This is my first boat. Wheres the best place to order things like the bullets? Also are the traxxas connectors any good for the batteries?
Diesel6401
11-04-2010, 10:48 PM
It's a 4s esc.
I haven't ran into any issues yet Rum on 5s with that esc and the bec disabled and connectors switched. If a failure occurs its all the users risk and not Proboats. I don't know if you will be able to get warrenty for that, even though the esc is rated for 21V operating outside of the manuals suggest setup is all the users risk!
Diesel6401
11-04-2010, 10:51 PM
I use 5.5 on everything. You can pick those up here at OSE (http://www.offshoreelectrics.com/proddetail.php?prod=ose-55bullet). If HH/PB doesn't warrenty the ESC grab yourself a 120amp or if you want to run a little higher voltage on the stock motor grab a seaking 80HV (http://www.hobbypartz.com/07e-c-seaking-80a-hv.html) then you can run 5s and even 6s on the stock motor. That esc is only rated for a min of 5s so 4s won't work. If you get a 120lv like a swordfish or seaking 120 don't run 6s stick to 4s and 5s.
POWERS
11-04-2010, 11:03 PM
Also when i use the program card, what should i have had the timing on?
Diesel6401
11-04-2010, 11:06 PM
Battery Type: Lipo
Cutoff Voltage: Low
Cutoff Type: Slow Down
Brake: Off
Timing: High
Throttle Curve: Linear
Boomer
11-05-2010, 12:57 AM
As nice as they are at Horizion Hobbies/Proboat I don't think they'll provide much warranty consideration on this one.
I copied this from the boats spec page on their site. "Accepts (2) 2S LiPo packs or
(2) 7.4V NiMH/Ni-Cd packs with deans connectors"
Thinking your 5s are a little beyond their published recommendations. I got a some 125A Turnigy to install to use when I add some more juice.
Couldn't hurt to ask!
I installed the Kintec off-set bracket today ran both the stock prop and a blue printed x642, with the batteries a 1/2" back from the battery trays. No bounce!
I am going adjust the angle of the shaft to give the boat a little more air. Ran very flat, turned great, but the bracket as I suspected, throws up a lot of water up to about 3/4 throttle. That is drag! I am going try the octura spacers on Friday to see how they compare. I don't think they will create as much drag.
The install was dirt simple and everything fits perfectly!
Boomer
POWERS
11-05-2010, 09:06 AM
I did the octura spacers myself. I only got 4 quick full throttle runs in but this thing was just flying across the water, I think the only part of the boat in the water was the prop and rudder, and it turned on a dime.
ron1950
11-05-2010, 10:44 PM
can the pb 60amp esc handle 5s at all or is that a smokeing hole waiting to happen?
tiqueman
11-05-2010, 11:05 PM
Put larger connectors on the motor and you shouldnt have any issues. Disconnect the BEC and run an external. A lot of people have been very successful doing so.. As I mentioned to you, I, unfortunately, was not one of them.. But it had to do w/ solder on the stock bullets letting go. I was also runing it in a slightly larger heavier boat.
tiqueman
11-05-2010, 11:40 PM
Wait.. the 60A is the Stilletto controller... Im not sure about that one. Disregaurd everything I said. I thought you were talking about the MG controller.
Diesel6401
11-05-2010, 11:44 PM
Their is no extended data that I can find on that esc that would give the voltage range. I would prob say don't try it or at least wait until some further information can be provided on that esc.
