View Full Version : Swordfish 120 Amp ESC and Leopard motro
dariomonguio
10-28-2010, 01:31 PM
what Time advance to Swordfish 120 Amp ESC and Leopard motror 4074
10-28-2010, 01:57 PM
Auto timing. Which kv motor and cells are you using?
dariomonguio
10-28-2010, 02:19 PM
2000 r/v 6s lipo 6000 hiperion, boat Riguer
2200 r/v 5s lipo 6000 hiperion, boat Riguer
and what to neu 1512- 2600rv?
10-28-2010, 02:51 PM
On 4s its probably pushing more than 100 amps. Those setup are more than a 120 amp esc will handle. I would definitely not run the 120 on those voltages and rpms.
dariomonguio
10-28-2010, 02:59 PM
2000 r / v 6s lipo 6000 Hiperion, barco Riguer , Swordfish 200 Amp ESC
2200 r / v 5s lipo 6000 Hiperion, barco Riguer , Swordfish 200 Amp ESC
y qué neu 1512 - 2600rv? 4s, Swordfish 120 Amp ESC
10-28-2010, 03:05 PM
2000 r / v 6s lipo 6000 Hiperion, barco Riguer , esc 200 a
2200 r / v 5s lipo 6000 Hiperion, barco Riguer , esc 200 a
y qué neu 1512 - 2600rv? 4s, 120A
I personally have not run a 2200 on 5s to know the results. But I have run a 2200 with 4s and 6500 hyperion 35c packs. (1) 4s pack was not enough. I had to run (2) 4s packs in parallel for good results.
dariomonguio
10-28-2010, 04:01 PM
in Spain the regulation only allows 1P
races are 5 minutes oval.
and weight of batteries is limited
Oval 1 (2s1p) 300gm
Oval 2 (3-4s1p) 590 gr
Oval 3 (5-6s1p) 895 gr
what you have rules of racing oval in the united states
what time?
what battery?
what category in riguer oval?
10-28-2010, 05:19 PM
For racing we have a 10,000mah limit. For heat racing its a number of laps.
Basstronics
10-28-2010, 05:54 PM
I got a low end KD3660 3000KV motor pulling well over 120 amps. I also have a Leopard 4074 2000 KV on the shelf here. After seeing an Eagle Tree on the KD3660 not a chance I would put a 120A ESX on that Leopard. Im not sure if 180 would be enough.
Ronbo
10-28-2010, 10:22 PM
A fellow scale racer that Im going to copy ran a leopard 2200kv, 442 prop, and 120amp speedo on 4s1p and did fine in a scale hydro. i ran against him and he had a lot of power and easily lasted 5 laps. Our courses are not small. fwiw...
