View Full Version : Recommend me a Lipo charger please...
Simon170
10-25-2010, 01:29 PM
I'm just getting into the whole Lipos thing and need to sort out a charger.
I've had a look around on Hobby King, but to be honest the choice is a bit overwhelming. I found the Turnigy MEGA 400W, which looked good, but I really wanted something that could be AC as well as DC powered.
I need something value for money (not cheap and nasty though), that can charge 6s, has AC an DC charging, balancer, and whatever feature are needed that I dont know about...:confused1:
Being able to charge two packs would be good, but I think that will be a bit too much too ask given my budget.
Many thanks for your help:thumbup1:
scullyeng
10-25-2010, 02:20 PM
I would look at the ichargers with their power supplies. Good value and lots of power.
mappo
10-25-2010, 02:30 PM
Really good charger that will charge at 15 amps.
http://www.offshoreelectrics.com/proddetail.php?prod=rcl-hyp-eos0615i-DV3
Jedi Master
10-25-2010, 02:40 PM
I have this charger and it is fantastic. I charge two 6s packs at a time. It's simple to use and does just about everything!!:thumbup1:
JimClark
10-25-2010, 02:57 PM
Do a search this question has been answered in much detail many many times before
Simon170
10-25-2010, 04:13 PM
Just been looking at the Ichargers, the iCharger 106B-plus 250W 6s Balance/Charger looks like a good bit of kit, although I'd have to get a power supply as well.
The Hyperion listed above looks amazing, but is a bit out of my price range.
hyrulejedi86
10-25-2010, 06:13 PM
Higher end charger (up to 15A) I am actually thinking about getting this next year.
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idproduct=12105
And Power source
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idproduct=13765
OR
A lower power charger ( up to 5A) I have this one and has worked great from day 1:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=7028
and power source
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6256
Simon170
10-25-2010, 08:09 PM
Some useful info there, thanks.
So
Turnigy MEGA 400
Vs
HobbyKing ECO6-10 200W
Vs
iCharger 106B-plus 250W (this seem to be the best, but also the most confusing in that you have to link it with you computer, why is that?
domp444
10-25-2010, 09:42 PM
I have the iCharger 206B with the P350 power supply. It's a great charger, and with the parallel cables I can charge up to 6 lipos at once. It will charge up to 6s lipos at 20amps. It's got all the necessary lipo features such as balance charge/discharge/storage/cycle. And of course, it can do just about any other battery you can think of.
Charger:
http://progressiverc.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=48&category_id=1&option=com_virtuemart&Itemid=1
Power Supply:
http://progressiverc.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=38&category_id=2&option=com_virtuemart&Itemid=1
Progressive R/C has a bunch of other chargers and power supplies that may better fit your need, this is just the one I have and usually recommend.
domp444
10-25-2010, 09:45 PM
You do not have to plug it into your computer to use it. The USB port is for updating the software and downloading stored charge logs from your iCharger. It's a great feature!
Snowride
10-26-2010, 06:08 AM
Here is what I have learned regarding chargers. A dual charger is based on 2 seperate chargers in 1 housing so basically you are paying for 2 smaller chargers. Throw in an integrated power supply which also adds quite a few dollars. Bottom line is a $250 ac charger is not all that great in features or value. Personally I decided to go with the 206B from icharger already mentioned. If you want to do more than 1 batt at a time just buy the required cables or better yet a second charger. :eek: If you do not want to lay out the cash for a power supply just yet, simply plugging it to your car batt will give you more than any power supply out there for power required.
I had a couple of 6 volt boat batts that I retired to my work bench which I use for several applications including my 206B. A dual batt setup like I have is overkill to say the least and definitely not required, just happened to have those lying around.
http://i56.tinypic.com/2cot207.jpg
http://i53.tinypic.com/ih0euo.jpg
Brushless55
10-26-2010, 12:20 PM
And Power source
OR
and power source
Wow, great find!
$35 for the 10A charger and $25 for the 16A supply :hug1:
Simon170
10-26-2010, 03:46 PM
Could you run an Icharger 208B from a Turnigy T20 power supply?
domp444
10-26-2010, 08:05 PM
Yes you can, but you will not be able to use it to it's fullest potential.
scullyeng
10-26-2010, 08:10 PM
You could, but the t20 does not put out enough power to make the 208b worthwhile.
You need to get a 25 amp 350 watt power supply to make the 208b run to its full potential. BTW at HK the 25 amp power supply is only 15.00 more than the T20.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9205
hyrulejedi86
10-26-2010, 08:54 PM
Wow, great find!
Yeah, it is! Like I said I think I'm going to do this como next year after some more reviews come out about the power supply. And hopefully it will hit the USA warehouse! :Praying:
Brushless55
10-26-2010, 11:38 PM
I have two of the other chargers you posted and they kick butt :rockon2:
and this bigger one will charge my 5000mah 5s packs quicker
