View Full Version : Swordfish 120 wont go to full throttle!
britscoot
10-20-2010, 04:18 PM
Anybody else had this problem?
Rumdog
10-20-2010, 04:28 PM
Is it programmed for the correct voltage?
britscoot
10-20-2010, 04:30 PM
i think so.
I have that little card with the dip switches.
Could that cause it?
Diesel6401
10-20-2010, 05:07 PM
Did you do the throttle calibration?
britscoot
10-20-2010, 06:05 PM
Calibration was done a while ago.
it worked properly then this problem came up.
is there away of re calibrating?
Thanks all for the help.
Diesel6401
10-20-2010, 06:33 PM
Check all the connections first if all are good re-calibrate the throttle. The re-calibration is the same as the first time you calibrate.
Pistol style transmitter calibration
- Correctly connect the ESC with brushless motor, plug the receiver lead of ESC into receiver ( usually into
Channel 2);
- Put the throttle to the forward full position, turn on the transmitter;
- Power on the ESC, there are 3 beeps emitted from the motor, which indicates all electronics are correctly
power on for the setting.
- Then there are 4 long beeps emitted from the motor ♪ ♪ ♪ ♪ .
- During or after the 4 long beeps , move the throttle to the neutral position. Two beeps emitting out
indicates calibrating is completed.
- Following two beeps are powering beeps, it is time to go now!
britscoot
10-20-2010, 07:14 PM
Its not beeping but i get throttle.
Just not full throttle.
Whats the correct settings ie cut off etc?
I sometimes get a red light on the esc when i pull the trigger to full.Motor spins.
