View Full Version : Building Jig Ideas
longballlumber
11-19-2007, 10:35 AM
Hello All,
I would like to hear some ideas and see some pictures in regards to building, a building jig. The whole pont is to have everthing straight, square, and flat. I am guessing one can be made using a tablesaw for getting straight accurate cuts. Also using the table to keep everthing flat while attaching the sides... Thoughts?!?!?!!?
JimClark
11-19-2007, 12:39 PM
Yup on the table saw. I also constructed mine out of 3/4 smooth MDF and glued and screwed the mdf surface on to plywood. This link shows one of my boats on the jig
http://www.classicthunder.org/SetUp/Buildingtips.htm
Jim
longballlumber
11-20-2007, 01:52 PM
Thanks for the reply Jim,
Does the surface of your building jig follow the curvature of the tunnel bottom, or is it completely flat?
Thanks
Mike
JimClark
11-20-2007, 02:27 PM
On most hydros the bottom is flat but there ia a break in the hull somewhere near the sponsons so it has about a 5 degree angle to it.
Jim
JimClark
11-20-2007, 02:29 PM
I just fixed the link
