View Full Version : JRS Innovations FE POWER STATION
JRS Innovations
10-15-2010, 09:17 PM
Hello All
To some of you this might seam like overkill, but I wanted to save my back as much as possible. I bought a 120 Amp Hour Deep Cycle trolling motor battery for my Charging set up I am gonna be using.
The Battery has a built in Handle but @ 60 lbs it is uncomfortable at best to lug it around.
The other thing I worry about is just the chance to short out the leads by accident.
So I have designed for my self a Battery enclosure that takes care of all of those problems.
It has 3 sets of 25 amp Banana Plugs, A Slo-Blow 30 AMP Fuse, A 30 AMP Toggle
& a Super Bright LED that can be seen in daylight.
I want to be able to use one charger, and maybe a second or third.
I can upgrade the switch and fuse to accommodate higher amperage draw of my charge but don't anticipate doing that.
Just thought I would get a feel if other FE racers would like something like this.
Thanks
Joe
teach
10-15-2010, 09:22 PM
Needs more cowbell IMO
weil0127
10-16-2010, 12:17 AM
Now I know what I need. Joe I will need one of these with my logo engraved on it.
:sold::bowdown::sold::bowdown::sold::bowdown:
raptor347
10-16-2010, 02:00 AM
OK, I like it.
What about making it a 40 amp circuit? I'd like to be able to run a pair of Hyperion Duo's at full rate.
How much are you thinking?
Doug Smock
10-16-2010, 09:21 AM
Nice work Joe.
Doug
detox
10-16-2010, 01:51 PM
According to the Hyperion manual you will need 24 volts (two 12 volt Deepcycle batteries wired in series) to get maximum output of Duo charger. The new AC/DC 720i-NET3-AD charger requires one 12 volt deepcycle battery to get max charge rate, but this is a slightly weaker charger than the DUO.
http://media.hyperion.hk/dn/eos/EOS-NET&DUO42-MAN-EN46.pdf
JRS Innovations
10-16-2010, 04:55 PM
That means you would need two of these with a jumper set of banana jacks to create the series circuit.......
Joe
Jeepers
10-16-2010, 05:29 PM
Joe
or just make one big one!!!
egneg
10-16-2010, 06:18 PM
I think they are a great idea and would like to get one for next season.
teach
10-16-2010, 07:23 PM
Yo Scarduchi, what's the dimensions of that thing and how much does it weigh with the battery in it?
JRS Innovations
10-17-2010, 10:49 AM
Hello Joe
I have not come up with a price yet, or what will be included.
I Will sell you one as soon as I set that standard.
What do you want engraved on it.
Thanks
Joe
JRS Innovations
10-17-2010, 10:57 AM
LOL "Scarduchi" I Like that name.....I am changing mine now, this week.
The Power Station specs are:
13 3/4" High
8 1/2" Deep
15 1/4" Wide
The unit by it self weighs 3 lbs.
With the friggin Battery it weighs 63 lbs......LOL
Thanks
Joe
Snowride
10-17-2010, 11:14 AM
Hmmm, got a similar setup on the bench at home as I have quite a few deep cycles from the boat. (The real boat that is ) so I decided to use them as opposed to a power supply. Only weighs #130 lbs and can deliver as much juice as any thing could ever demand. 200 amp hr 6 Volt Trojans (not the condoms) batteries. :banana:
http://i56.tinypic.com/2cot207.jpg
