medina619
10-13-2010, 10:14 PM
looking for a brushless motor for my RIO EP. which one would you drop in?:confused2:
Turnigy B36-40-07 2900kv Inrunner
Spec.
Kv: 2900rpm/v
Power: 375W
Turns: 7
Resistance: 21
Idle Current: 2.5
Esc: 45
Battery Config: 3-4S
Length: 42mm
Width: 36mm
Shaft: 5mm
Weight: 170g
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6532
or
Turnigy B36-30-10 3200kv Inrunner
Spec.
Kv: 3200rpm/v
Power: 310W
Turns: 10
Resistance: 48
Idle Current: 3.8
Esc: 35
Battery Config: 2-4S
Length: 35mm
Width: 36mm
Shaft: 5mm
Weight: 120g
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6534
Spec.
Kv: 2900rpm/v
Power: 375W
Turns: 7
Resistance: 21
Idle Current: 2.5
Esc: 45
Length: 42mm
Width: 36mm
Shaft: 5mm
Weight: 170g
or
Spec.
Kv: 3200rpm/v
Power: 310W
Turns: 10
Resistance: 48
Idle Current: 3.8
Esc: 35
Length: 35mm
Width: 36mm
Shaft: 5mm
Weight: 120g
