View Full Version : Turnigy 80amp/12s haha
b.mcdaniel.2009
10-12-2010, 08:30 PM
Just fryed my Turnigy 80amp esc on 10s a few days ago. Didnt even get a chance to do a run. Just went up in smoke at about 1/2 throttle:doh: Had 2 3s packs and 2 2s packs. All same brand c-rating and mah. Did i do something wrong hear or did i just get a *!***!***!***!**ty esc.(Was even programmed properly):confused1:
britscoot
10-12-2010, 08:49 PM
Wow!
thats a lot of juice to put through an 80amp esc.
How do you guys do it?
Poor thing....lol
b.mcdaniel.2009
10-13-2010, 05:37 PM
Anyone?
lectriglide
10-13-2010, 05:52 PM
Dude - what motor, what prop, type of boat???? Can't even begin to say without all that info.
If it was the apparition cat with the Turnigy 600 1400kv you need to go back to the drawing board and study setups. That motor is rated @ 110 amps and suggests a 150 amp speed controls. Do you really wonder why it went pooooooof with an 80a esc?
Flying Scotsman
10-13-2010, 06:57 PM
One word......READ and then follow instructions...what Turnigy ESC ....prop. hull..etc...state your finished hull with all components and not a stupid post
Douggie
FighterCat57
10-13-2010, 07:44 PM
Over propped/RPM'd it and too high of KV for the ESC. 10s 1400kv is 51k RPM.
For 10s use the 880kv model motor. With 1400kv, use the 6s 180a ESC and you're good to go.
I have a T80 HV that I run on 8-12s, but that's with a 38mm prop and 880kv.
b.mcdaniel.2009
10-13-2010, 09:29 PM
Douggie
Not a stupid post. If you read it i didnt even get into the throttle! I was just saying what happened.:blah:
b.mcdaniel.2009
10-13-2010, 09:30 PM
Jesus whats up with the aditude! Oh and motors FINE!
Ya fighterCat your right i just didnt think man just got excited, i've never had an esc that was 12s stable:)
FighterCat57
10-13-2010, 09:56 PM
(don't pay any attention to it)
I get excited and burn stuff up to. Just learn from it and build more better faster! :w00t:
Flying Scotsman
10-13-2010, 09:59 PM
Still waiting for all the facts and your setup.:olleyes:
Douggie
Rumdog
10-13-2010, 10:03 PM
DID YOU hook up 12s to a hv 80 amp controller and a 1400kv motor? There are far more problems there than you may think. Good thing you didn't get it in the water!:flame42:
FighterCat57
10-13-2010, 10:14 PM
I can help explain, since I sold him the boat.
I was selling two boats, a. 1400kv, no speedo b. 880kv, 80HV speedo. Both Apparition hulls, painted with same looking setups. There was a lot of talk about running boat b on 12s and running boat a on 6s w/turnigy 180a. I've had fairly good luck running the 80HV on 8, 10 and 12s in boat b. He chose boat a and needed a speedo. At the time I didn't have any high amp ESC's.
Being excited about a new boat, there must have been some confusion on the setup info which resulted in the 80HV being hooked up to the 1400kv motor.
To a pro, mis-matching KV/Volts is a stupid mistake. To a sport boater or somewhat new FE boater, it's an easy mistake. Especially when there's a very similar setup with very close numbers.
Make-a-Wake
10-13-2010, 10:18 PM
Im confused here...........the OP has made four posts and still has not shared/confirmed his setup.............unless its the 1400kv being tossed around
Rumdog
10-13-2010, 10:19 PM
Ahh. I see.
FighterCat57
10-13-2010, 10:22 PM
Im confused here...........the OP has made four posts and still has not shared/confirmed his setup.............unless it the 1400 being tossed around
I can. I built it. 1400kv 4030 Outrunner, 078 wire, K45 prop. 32" Apparition Cat Hull.
Good for 6s/200a ESC for 50+ mph. (Video available in the Project Apparition Two thread. )
Bad on 10s/80a ESC
JMSCARD
10-13-2010, 10:24 PM
:rofl:
yes def looks as though he ran the 1400kv motor on 10s.... hence why it probably blew at half throttle... at that point he was running about what rpm the motor should of been at while full throttle on 5s or 6s... Oh well like FC says... very minor stuff.... at least it wasnt as super expensive esc.... could have been worse..... just a $80 day on the water.... in FE thats minor....lol...:rofl:
lectriglide
10-13-2010, 10:33 PM
Ben
I was curious and looked back at your apparition sale thread. You were pretty clear about the 1400kv motor being a good 6s setup with a 180a or 240a esc. Brad was looking for and passed on at least one 180a esc, then for some reason settled on the 80hv ($$$)?? over several suggestions on higher amp esc's. Unless he's got $$$ to burn like he just did, hope he slows down and does some reading, studying and listening to the experienced guys on here that are very very willing to help keep this exact type of thing from happening.. :doh:
b.mcdaniel.2009
10-13-2010, 10:35 PM
FighterCats on it!!!! Thanks man!!! Ya first i ran the apparition on 5s with a 45mm prop. Ran great, handeling great. Just had the batterys lieing there waiting to be used lol. Just gonna use this as a lesson, high volts, low kv motor. Cheap esc anyways!!
Rumdog
10-13-2010, 10:38 PM
ANY esc. Or motor for that matter. Try for a target rpm from around 27000 to 33000. More is just asking for trouble if tou don't have a very well trimmed setup.
b.mcdaniel.2009
10-13-2010, 10:41 PM
No orignally i had the 180 amp esc i bought in the apparition running 4s, but my Leopard 4082 came in for my Genesis and decided to run it with the leopard, 5s 48mm prop.
Ya my Genesis is around 35,000 if im correct.
Flying Scotsman
10-13-2010, 11:01 PM
Bad on 10s/80a ESC
That explains a lot. b.mcdaniel.2009 you are on your own and do not drag your fight on to this forum and we still do not know your setup.
Douggie
b.mcdaniel.2009
10-13-2010, 11:03 PM
It all boil's down to me getting excited to have a 12s sable esc and not thinking about the motor kv rating(what rpm it was going to be). Common ROKKIE mistake. Ill just learn from it. I hope i didnt afend anyone with my posts and wanna thank the guys on ose that have helped me get started and the great info they have gave me!!!!!!:)
b.mcdaniel.2009
10-13-2010, 11:07 PM
Douggie
FighterCats Apparition cat.
1400kv turnigy outrunner
80 amp turingy esc
10s (obv. not good)
There was no fight to be brought on here.:Peace_Sign:
10-19-2010, 10:30 AM
Douggie
After receiving more complaints about more of your responses, I was pointed to this thread.
This is no way to start a conversation about the guys setup. I was going to permanently ban you but Danny saved your butt. It is the last time for this. You are on notice.
tharmer
10-19-2010, 12:51 PM
Thanks, Steven.
-t
