View Full Version : MHZ FOUNTAIN and CASTLE 1717 1580kV
Alfa Spirit
10-11-2010, 09:22 PM
Because very low prices from Castle Creations I bought a 1717 1580kV motor and I' m looking for a deep vee hull capable to work with this motor.
MHZ FOUNTAIN 39" should be fine with 6S 1P or 2P batteries, what do you think guys?
Technical Details:
Length: 980 mm (39 inch)
Width: 215 mm (8.5 inch)
Weight: 745 g (26.3 oz)
forescott
10-11-2010, 09:53 PM
I think it will work fine with a smaller-ish prop. Definetly 6s2p. The new 200amp LV esc that OSE will be stocking in the next couple of months should work well with this motor too.
westbeach
10-11-2010, 10:02 PM
Alfa,
That is a very nice hull, looks like you and Jesse will have to have a build off, if you both end up getting the same hull. :bounce: I'll be watching closely. :buttrock:
Technical Details:
Jesse J
10-11-2010, 10:17 PM
Ya baby, you know what they say about great minds, cheap Castle motors and sweets boats... Alfa, I hooked up my 1717 to the water cooled outrunner motor mount I got from Williams Racing and it fits perfectly, you could get one (be sure you get 25 mm bolt spacing) for a little cheaper that isn't water cooled - probably don't need it.
I don't have my hull yet, but will start me a build thread - will be great to compare notes as we go. Yep I was thinking 6S2P and 45-47 mm prop - probably won't be able to go much more w/o heat issues.
westbeach
10-11-2010, 10:26 PM
Jesse, how soon till ya get the boat?? Any ideas on harware? Scale drives??
Brushless55
10-11-2010, 11:30 PM
looking forward to this one :thumbup:
JEDNJONES
10-14-2010, 01:53 PM
I might have to copy you guys too. I just cant find a realistic stepped Fountain anywhere in this size range. So...Dragon Lady is looking good for a winter build. Anxious to see wich drives you guys are going to use.
Jerry
Alfa Spirit
10-14-2010, 04:20 PM
I will run this Fountain 39" hull with this setup. Trimax is great and expensive :tongue_smilie:
http://img545.imageshack.us/img545/9123/mhztrimaxmini.jpg
http://img706.imageshack.us/img706/8519/setup5s.jpg
Alfa Spirit
10-14-2010, 05:32 PM
Complete cheap 3/16" deive from china : http://cgi.ebay.fr/Adjustable-Stinger-Drive-Kit-For-3-16-Shaft-Boats-NEW-/270574264870?pt=UK_ToysGames_RadioControlled_JN&hash=item3eff7ba226
Flying Scotsman
10-14-2010, 06:20 PM
Jerry
That is very nice hardware, but the dumb twit that I am , explain how it functions.
Douggie
forescott
10-14-2010, 06:30 PM
The flex shaft has a square end that slips into the square female end of the black propshaft, which in turn slips into the stinger from the rear. Stock hardware from the HK osprey!
Flying Scotsman
10-14-2010, 06:36 PM
http://img508.imageshack.us/img508/8519/setup5s.jpg
I replied to the wrong post.
Douggie
Alfa Spirit
10-15-2010, 08:53 AM
Nice hardware here, MTC https://www.mtc-powerboat.de/index.php?lang=en§ion=13&produkt=6&variante=83
CornelP
10-15-2010, 08:59 AM
Douggie, the main idea here is that you can adjust the strut in 2d instead of the usual 1D. Decent thing if you want to get rid of some of the torque effects... but then again you can offset the strut from the beginning...
Anyway, Trimax and MTC are usually designed for gas boats, so big wires...
JEDNJONES
10-16-2010, 08:34 PM
Wich size Trimax is that? I dont see that one on MHZ w/ that brass fitting on top. I am tossing around the idea of twins in this thing. Those SSM#6 drives look awesome but are too big and expensive.
keithbradley
10-16-2010, 08:43 PM
Douggie
The hexes on each of the three rods are threaded left and right hand thread, so you can lengthen and shorten the rods by turning the hex (without removing them). By turning the hexes you change the rod length and in turn change the strut angle.
Is that what you were looking for?
JEDNJONES
10-18-2010, 04:36 PM
Guys, I just spoke with Lowe at MHZ and I want a white hull. He has yellow in stock and is willing to shoot a batch of white if he has enough interest. Can you let me know if you guys are looking for white Dragon ladys?
Thanks,
Jerry
Heath M
10-18-2010, 06:02 PM
This strut would look good as well http://www.mddracing.com/Home_ban_Ls.htm click on hardware
Alfa Spirit
10-23-2010, 07:30 PM
The Castle 1717 arrived in France, MHZ Dragon Lady Fountain should be at home at the end october :w00t:
I was looking to MHZ Racemaster but I really like de Fountain design, what do you suggest for the rudder: center or on the right side? Or may be two rudders?
http://img177.imageshack.us/img177/6425/mhzfountain4.jpg
Alfa Spirit
10-23-2010, 10:36 PM
What do think about MTC PowerTrimm V for the Dragon Lady hull? See attached file
Length = 90 mm / 3.55"
Thank you
westbeach
10-23-2010, 10:50 PM
Alpha,
The MTC powertrimm V is very nice. I would invest in one if they were easy to buy.
Alfa Spirit
10-23-2010, 11:05 PM
Yes westbeach this is a nice part, price is double than a chinese stinger. I don' t know if the lenght is correct for this hull
westbeach
10-23-2010, 11:20 PM
Alpha, yes the pwertrimm is too short for the fountain hull, you need at least 10cm length for the fountain like this https://www.mtc-powerboat.de/index.php?lang=en§ion=13&produkt=1
Alfa Spirit
10-23-2010, 11:30 PM
The difference of lenght between those 2 parts is only 1cm. I' m not sure this is important, this centimètre is expensive :laugh:
Lenght of stinger is approx. 10% of hull' s lenght, is it right?
How many rudders? One or two,
Alfa Spirit
11-03-2010, 12:57 PM
The motor arrived, it' s big and magnets are very strong, a nice motor for low price, good deal
http://img831.imageshack.us/img831/777/temp20.jpg
Brushless55
11-03-2010, 01:14 PM
very nice man!
I have one of those ging into a Outlaw OBL
http://forums.offshoreelectrics.com/showthread.php?t=19194
Alfa Spirit
11-03-2010, 01:24 PM
What is the lenght of your Outlow? I will run the 1717 with 5S 2P parallel
Brushless55
11-03-2010, 01:56 PM
The Outlaw is 39" and I'm going to start with 5s2p, then get some 6s packs and run 6s2p..
Make-a-Wake
11-03-2010, 03:00 PM
I just got done installing my 1717 in my 40" fountain Vee!
Alfa Spirit
11-03-2010, 03:29 PM
Do you have pictures?
Alfa Spirit
11-04-2010, 03:48 PM
Here is the MHZ Fountain :bounce:
http://img801.imageshack.us/img801/9476/te3.jpg
Make-a-Wake
11-04-2010, 10:23 PM
Wonder if an x442 will be a good prop choice for my 40" Vee with the 1717 on 6s..........???
At least a starting point....................
Brushless55
11-04-2010, 10:54 PM
I think bigger?
I have the stock S225 on my Outlaw that I will keep on it when I try my 1717 on 5s and 6s
Make-a-Wake
11-05-2010, 12:17 AM
Maybe so................i was wanting to start on the small side..........check temps etc.............and work up. It may well end up being a 445, 447 or s225............thanks.
Brushless55
11-05-2010, 11:02 AM
I hope to be able to go upto a S230 and possibly a S235
Alfa Spirit
11-05-2010, 01:50 PM
DISAR build a MHZ Racemaster, his hull is 1 meter long like the Fountain. A Castle 1717 on 6S will give too much RPM, I think 5S will be ok, around 30000RPM, 5S 2P (parallel) should be a nice setup
Alfa Spirit
11-06-2010, 02:42 PM
What do you think about this hardware, lenght is 9cm ( 3,6"), is it enough for a 39" hull?
This hardware is expensive, If you have links to cheaper hardware that' s great :help:
http://img573.imageshack.us/img573/6513/mhzmtcpowertrim1.jpg
DISAR
11-08-2010, 04:24 AM
The prop distance behind the hull is one big question. normally is 10%, but when I asked MHZ for the racemaster they said 55mm which is quite small I believe. I have it at 85mm and I use the eco trimax but I think that the speedmaster stinger is far better. I recommend the speedmaster stinger, very good quality, 83mm length and cheaper. 3/16 flex, teflon and 9/32" tube. the teflon just fits in the stinger very nicely.
If you want longer distance you can install a distance piece on the transom or elongate the stinger, but need to find out how ...
Make-a-Wake
11-08-2010, 06:08 PM
I guess the 442 was too small, took my first run with my 40" fountain with the 1717 on 6s. Ran very well.............not a huge speed difference from the Feigao 580L but definately faster.............the thing is though, the 580L would come in at 125*, and the ESC fairly warm too. This motor came in after a 3 minute run at 78*..........yep...........78*. ESC was 83* and caps 89*, its a Seaking 180. This big boy wasnt even loaded up and i imagine that loading it would wake it up. I think the s230 mentioned by Brushless55 would be a good fit...........that or an Octura x447. I'll play with it.................
Rumdog
11-08-2010, 06:13 PM
That motor will spin a MUCH bigger prop!
Good luck with the Seaking on 6s though.
Brushless55
11-08-2010, 07:13 PM
Bam!
this is very awesome, another great run on the 1717!
let us know how the S230 or the X447 run. I will buy a prop for my OSE Brothers Outlaw after you run yours :banana:
do you have a cooling jacket on your 1717?
Make-a-Wake
11-08-2010, 07:24 PM
Bam!
:bounce:
Brushless55
11-08-2010, 07:27 PM
:bounce:
what motor mount do you have?
I am having Peter make a mount for me, but I'm not sure that jacket will fit? :confused2:
and what do you guess your speed to be on the run?
Rumdog
11-08-2010, 07:31 PM
Steve has jackets in stock now!
chummer
11-08-2010, 07:34 PM
Outta stock by morning I bet!
Alfa Spirit
11-10-2010, 08:39 PM
Are you talking about this 3/16" Speedmaster Stinger Strut? http://www.offshoreelectrics.com/proddetail.php?prod=ros-stinger-str
What 3/16" prop shaft and what 3/16" flex shaft work fine with the Speedmaster Stinger?
Thanks
DISAR
11-12-2010, 07:00 AM
Alfa yes, this stinger, I believe that you have all the items needed for the shafting.
Alfa Spirit
11-12-2010, 10:44 AM
Thank you for your help DISAR, parts are on the way;
The Speedmaster strut for 3/16'' look fine, What about the lenght 82,5mm?
K.R.Joye
11-12-2010, 11:12 AM
Not sure if you seen my post on RR this is my current setup with uncooled 1717/1580
40" AM Sprint Cat
Etti HV 200 amp water-cooled ESC
6S1P 30C 4500 Lipo
X450/3 Prop detounged / 53MPH GPS no heat on anything
X452 Prop detounged / 57MPH GPS no heat on anything
I'm likin these motors!
Gerwin Brommer
11-12-2010, 11:29 AM
Alfa :
The Speedmaster Stinger is even better than the others.
Why ?
You can adjust not only the angle, but also the HIGHT of the shaft !
Lenght : 10% is not a "rule".
Works well on stepped mono's with a SAW-setup.
For a normal setup/hull you don't necesseraly need 10%
Alfa Spirit
11-15-2010, 06:32 PM
The Castle 1717 with his water jacket is a monster, great !!
Alfa Spirit
11-20-2010, 02:08 PM
Parts of hardware are on order The flexshaft and the coupler come from Dave Marles, out of stock at OSE
Make-a-Wake
11-21-2010, 10:45 AM
Have this hull on the way for my Castle 1717. The old hull wasnt performing to my liking. Gonna run it on 6s............its 39.5".
Question is, which prop? I'm thinking in the x445, x447, x642, x645 range. Any suggestions are very welcome and appreciated!
Brushless55
11-21-2010, 11:05 AM
Looks like my Thundertiger OBL :thumbup1:
forescott
11-21-2010, 11:28 AM
I think the x452. Those props are kinda small for a hull that size. I ran the m545 on a castle 2200 with no heat issues. The 1717 will push those props without breaking a sweat!
Make-a-Wake
11-21-2010, 05:16 PM
OK...........seems kinda big, but thats why i asked. Thanks!
Alfa Spirit
11-24-2010, 01:45 PM
I need help guys, how many rudders for the MHZ Fountain? I think that I will install two rudders for stability, what do you think?
DISAR
11-26-2010, 07:41 AM
If it is the thunder tiger OBL, it can do well with small props as well. I ve seen one with a prather 220 and a 642. Depends on the position of the strut, if it is low small props can work, if it is high you need bigger props.
Depends also on your esc, 225,230,445,645 are definately safe, then if temps-amps are ok bigger ones can be used
Make-a-Wake
11-27-2010, 11:10 PM
Thanks DISAR................ got my hull in, got all the parts too.................just gotta pace myself as i tend to wanna rush things a bit and i want this to be as close to perfect as i can get it.
Not trying to hijack your thread alpha..........we both have 39" mono's with 1717 power and i thought id share mine as well.:smile:
Brushless55
11-28-2010, 12:53 AM
I think yours make for 4 of us building a 39-40" mono with CC1717 power :rockon2:
Make-a-Wake
11-28-2010, 01:17 AM
Great!..........nice lookin' boat in your thread................hadnt seen that one. i'll be following it!:buttrock:
Alfa Spirit
11-28-2010, 11:14 AM
Yeah! Nice boat :rockon2:
I think I' ll use 2 rudders for my MHZ with a symmetrical assembly and water inlets
Alfa Spirit
11-29-2010, 02:34 AM
Nobody? :confused1:
DISAR
11-29-2010, 04:45 AM
why not buying the twin rudders set?
to be honest I don't know if twin rudders will add stability.......?
Alfa Spirit
11-29-2010, 05:42 AM
Twin rudder sets on Ebay don' t have water inlet.
The Speedmaster stinger is 115mm long with the DD and the propeller, this model should work :confused1:
If the rudder is to long I can cut it, water inlet is high, but I want to know if a symmetrical mount is possible
Alfa Spirit
11-29-2010, 07:42 AM
I' ve got the answer :banana: :rockon2:
Alfa Spirit
11-29-2010, 02:00 PM
Speedmaster strut, flexshaft and coupler. Speedmaster is a nice part :thumbup1:
http://img688.imageshack.us/img688/2176/mhzfountain33.jpg
Alfa Spirit
11-30-2010, 07:15 AM
Total lenght of the Speedmaster strut , drive dog and flexshaft is 120mm
DISAR
12-02-2010, 04:06 AM
I was looking around for twin rudders as well and now realized your point...........
You were referring to the brackets arrangement, so it is possible.........isn't it? Are you going to use two servos or one servo and interconnect the rudders? how?
Alfa Spirit
12-02-2010, 06:29 AM
Exactly, it is possible with those rudders from Promise Hobby they are symetric, only one servo with good linkage
http://cgi.ebay.fr/160mm-rudder-for-67-to-90-or-23-26-cc-for-rc-boat-/140313072367?pt=Radio_Control_Parts_Accessories&hash=item20ab4f92ef
Alfa Spirit
12-02-2010, 01:25 PM
I will interconnect the rudders I' ll see how to when rudders will be at home. May be a U inverted part aluminium made fixed with up screws
Alfa Spirit
12-06-2010, 05:47 PM
MHZ Fountain Vs MHZ Racemaster, bottom of those hulls are very similar
http://img37.imageshack.us/img37/1739/racemasterfountain1.jpg
http://img337.imageshack.us/img337/2562/racemasterfountain2.jpg
Alfa Spirit
12-08-2010, 03:13 PM
I need advice please: trim tabs or not for this MHZ hull? Speedmaster 1 1/2" x 1 1/2" tabs, not a large model
Alfa Spirit
12-10-2010, 08:04 PM
The CC 1717 is a high torque motor. What' s best way to adjust the boat going straight?
Alfa Spirit
12-14-2010, 03:29 PM
http://img411.imageshack.us/img411/9233/mhzfountain32.jpg
Alfa Spirit
10-02-2011, 11:05 AM
I wanted to sell the MHZ Fountain hull but finally NO :laugh: Now I have complete hardware :w00t: Thanks to Herve for CC1717 motor mount :thumbup1:
Alfa Spirit
10-03-2011, 10:50 AM
I hope turn fins won' t be necessary, I really hate turn fins for semi scale offshore :angry:
Check this :banana:
http://img849.imageshack.us/img849/6484/hardware1.jpg
61562
srislash
10-05-2011, 11:09 PM
I am dying to this go.Was gonna jump on it in the sale thread but glad you decided to see it through.
A three blade prop i think x447-x646 on 5s 2p.
I realy like that hull for salt water.
