View Full Version : Leopard 4082 timming
b.mcdaniel.2009
10-10-2010, 11:45 AM
Just installed my 4082 1600kv motor in my Genesis with a 180amper esc running 5s and made a few passes, gps 56mph at 3/4 throttle with a 48mm prop, no heat at all and used only 1200mah outta my packs. My main question is what to set the timming for the motor?:confused: Plus i think its def. got more to unleach, any suggestions on a different prop????
cacofonix
10-10-2010, 02:03 PM
hello
for my 3674, i set my esc to 7°
really amazing motor
herve
b.mcdaniel.2009
10-10-2010, 05:42 PM
Thats what i set my esc at and finally got the chance to do a few wide open passes today(water was much calmer) and WOW this thing flys!!!!! But my temps were not even warm so im thinking bigger prop?????
carlcisneros
10-10-2010, 07:41 PM
take the prop and carefully put just a titch of inward roll on the leading edge close out to the tips.
JUST A SMIDGE at a time.
this will start to narrow the spray down so you get more forward motion instead of super sized rooster tailing.
Carl
remember, RPM equals speed
keithbradley
10-10-2010, 08:04 PM
Low temps are what you are aiming for my man:thumbup1:
Dont try too hard to push it to the point that it is getting hot. It is a water cooled setup and if you get to the point that it is getting hot you are probably pushing it a little harder than you should. These motors will run nice and cool right up to the point that you cross a line and work them too hard. I ran that motor on 6s2p with a s220 prop and it pulled a little over 100A. I also ran it on 6s2p with a s225 and saw amp spikes as high as 209A, with 160-170A being fairly normal draw at a full throttle hit. It waasnt hot when it was pulling that amount of current either.
My point is you will get to a point where a small change makes a huge difference.
It sounds like you got it hauling pretty well...I hope you are pleased with the motor:banana:
The only suggestion I have is if you start having handling issues with a larger prop you may want to try 6s and a (lot) smaller prop.
EDIT: GET SOME VIDEO!
b.mcdaniel.2009
10-10-2010, 08:09 PM
ya with the 48mm prop it was al little hard to handel:rofl:
I been thinking about runnung 6s but i dont wanna strain motor/esc.
keithbradley
10-10-2010, 08:22 PM
Try 6s on a s215 or x442 and check you temps. You would love the way it handles with the smaller prop Im sure.
b.mcdaniel.2009
10-13-2010, 05:36 PM
Tryed 6s today with a 45mm prop, wasnt bad but i liked the way it ran on 5s with the 48mm prop. Not so much torque roll.Plus i dont wanna stress that 180esc.
