View Full Version : NUE Power on 4S
JEDNJONES
10-07-2010, 07:01 PM
Here are pics of the new power installed in the Fountain.
NUE 1512-2D 2550KV
Seaking 180 ESC
10ga wire/6mm bulletts
(2) x Hyperion VX G3 6500 2S
X442 B/S
Jerry
http://i866.photobucket.com/albums/ab227/jednjones/P1/100_1217.jpg
http://i866.photobucket.com/albums/ab227/jednjones/P1/100_1218.jpg
http://i866.photobucket.com/albums/ab227/jednjones/P1/100_1220.jpg
http://i866.photobucket.com/albums/ab227/jednjones/P1/100_1222.jpg
http://i866.photobucket.com/albums/ab227/jednjones/P1/100_1223.jpg
http://i866.photobucket.com/albums/ab227/jednjones/P1/100_1221.jpg
Rumdog
10-07-2010, 07:53 PM
Did you pull it 54 mph behind the Slash?
JEDNJONES
10-07-2010, 08:38 PM
Heck yes I did. And I was taking it easy!
forescott
10-08-2010, 12:54 AM
How did it handle? Where was all the water coming from? Looks pretty wet inside.
JEDNJONES
10-08-2010, 10:27 AM
Hi Forscott. You can see in the pictures the window on the port side is laying by the motor. I finally got the straight line stability I wanted. Was running faster yesterday but flipping too much.
I dialed the stinger to zero and made it run a little wet so I lost around 6 mph. but I can run wide open now. virtually no torq roll now with the higher KV motor. I am now working on the turns. Spins out if I run too much servo travel. Maybe I will order those fins now.
Also, I had to lay another layer of glass inside the hull. It cannot handle the beatings at these speeds. Now the windows are the weakest point. Im sure the 4mm Flex will shred soon too.
Jerry
forescott
10-10-2010, 11:48 AM
Good to know. I may add a little epoxy around the windows for sure!
Brushless01
10-16-2010, 02:43 AM
Does this boat have 4mm drive ?
forescott
10-16-2010, 09:09 AM
Yes, the p-1 has a 4mm flex/propshaft
JEDNJONES
10-16-2010, 12:51 PM
Speaking of the 4mm flex. As I thought would happen, it frayed at the end by the motor. Was unable to repair. I cannot find a replacement anywhere. If I go up to .150, It looks like id need to upgrade the drive. anybody have any suggestions?
Thanks,
Jerry
forescott
10-16-2010, 01:23 PM
I would say use one from the c-1 cat but its too short. The flex really needs to be soldered to keep it from coming apart. Venom probably doesnt have any parts in stock either.
forescott
10-16-2010, 01:37 PM
My flex shaft is too short as it is. Its not long enough to reach the second set of screws on the coupler. Figures!
JEDNJONES
10-16-2010, 01:47 PM
Yes, Your right. Its already too short. and no parts available yet. I just emailed rcraceboats to see if I can buy a wire setup. I need this thing back on the water asap before winter. Have more tuning to do.
forescott
10-16-2010, 01:50 PM
Wire drive, great idea! I have them in my C-1 and love em! Heres a link to the fins I got.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220465059358&ssPageName=STRK:MEWNX:IT
JEDNJONES
10-16-2010, 01:58 PM
Those look good. How long did it take to get from Hong Kong? The price is right for sure.
hobie
10-17-2010, 12:50 AM
Thanks,
Jerry
Jerry, I ended up making my drive into a pretzel!! And I was only running 4s. I took a cable from a .130 flex system, soldered the end, filed it down to fit in the stock drive end. Also was able to use a small piece of teflon as well, up on the motor side. Had to solder and file the coupler side as well.
Not sure how it's going to work, haven't run it since that conversion. As soon as I do, I will post my results.
It looks like it will work well, but since it's not much bigger than the stock flex, it might not hold up much better. But I didn't want to have to rebuild the whole drive as of yet. Maybe over the winter.... Lol
JEDNJONES
10-17-2010, 10:17 AM
That sounds like another option as well. Thanks for letting me know. I am trying to find the correct wire drive parts to order but, im having a hard time finding the longer cable length...so, .130 may be another choice.
Jerry
forescott
10-17-2010, 10:45 AM
I'm working on getting a wire drive for the p-1 as well. Same drive as the ekos, just longer wire. And Jeff has the 5mm to .062 couplers.
JEDNJONES
10-17-2010, 05:10 PM
When you figure out what parts to order, please let me know.
Thanks
996TURBO
11-03-2010, 11:29 PM
54 mph is mighty fast on 4s. You have that boat dialed in :thumbup1:
JEDNJONES
11-09-2010, 10:29 AM
Thanks. She runs pretty good but, its down for awhile. The 4mm cable didnt hold up. I heard your building a cat to run next year at the Northern MI RC Kilo runs...is that true?
Had fun runnin with ya this year at the mini poker run.
Jerry
Jesse J
11-09-2010, 11:01 AM
Ya, I don't think they had us in mind when they opted for 1/8" flex... I bet Jeff could make a .150 flex that stepped down to 4mm for the strut, or wire drive, I am sure he could do 4mm on that. I would feel better about .078" wire, as I have snapped the .062 before on high power/load situations. You could even go .098 for some beef - as long as your tube is low curve.
JEDNJONES
11-09-2010, 11:11 AM
Yea, Ive emailed Jeff my specs and hes supposed to put somthing together for me. Ive just missed out on running it the last 3 weeks. The .150 / 4mm sounds like a good idea. I am not opposed to a whole new flex/stinger/rudder system. If I can find somthing that looks scale. I need somthing before my lake freezes too.
forescott
11-10-2010, 12:35 AM
I just got .062 wire drive w/4mm shaft and an octura 5mm to .062 hex collet for the p-1. .062 wire has held up so far on my ekos running x442 props, so I would think it would be ok on the p-1 as well.
Jesse J
11-10-2010, 12:49 AM
Keep in mind that the power systems in twins work much less than single motor set ups. It could be a good set up though. I will be interested to see how you like it.
forescott
11-10-2010, 01:31 AM
I just figured its turning the same prop, and at less rpm than my ekos. I would have ordered larger wire, but I don't think .078 wire fits in a 4mm shaft. We'll see if it stays together!!
JEDNJONES
11-10-2010, 03:14 AM
Where did you get a longer wire setup for the P1 Scott? You only sold your hatch, Not your whole boat right?
Jesse J
11-10-2010, 03:19 AM
well, .125" flex fits, so .078" wire would have to. If you stay with 42mm and smaller props, you probably be fine. Might run some plastic props at first.
Actually, I broke mine because I was not absolutely in line motor-stuffing and was invoking a bit of a pressure point.
JEDNJONES
11-10-2010, 04:02 AM
Jesse, Do you have anything laying around that would get my boat back in the water?
forescott
11-10-2010, 08:53 AM
Jeff Wholt @ rcraceboat.com. You have to send him a PM to get the longer length wire.
forescott
11-10-2010, 08:54 AM
Mine lines up horribly as well. Been trying to shim and grind the mount to straighten it and lower it at the same time!
forescott
11-10-2010, 08:55 AM
What parts do you need?
Jesse J
11-10-2010, 11:55 AM
um well Jed, I do have a brand new flex line 1/8" to 4mm that came with that MHZ hardware. I was able to salvage the ruined one I got from Brad in my MHZ Fountain. So I do have this flex that I ran in my P1 before gutting, so I know it is long enough. I was hoping to hang onto it - but due to ponds' eminent freeze, I think I could spare it if it gets you back on the water.
I could let you have it for $20 shipped. No drive dog - but can include liner if you need.
Other than that, I have nothing with 4mm stub.
Jesse J
11-10-2010, 12:04 PM
If my inline set up doesn't work, I was considering going the traditional offset route. In that case I was looking at either speedmaster stinger strut and rudder or something similar. I was thinking that since this hull is prone to lift in headwinds, a more set back prop might help (i.e. the stinger or my fabrication). That would also get you back to .150" flex, 3/16" stub and a simpler life
JEDNJONES
11-10-2010, 05:46 PM
Forscott, at this point im waiting for Jeff to build me a wire drive. In the meantime ill buy anything that will be a direct replacement for the 4mm flex that I broke.
JEDNJONES
11-10-2010, 05:51 PM
Jesse, Only if you dont mind parting with it. I assume I would be able to use the stock drive dog? Also, would I need a different motor coupler or will the 1/8 fit? And, yes I would need the liner.
Jerry
996TURBO
11-10-2010, 06:10 PM
JEDJONES - I will get yeah on the next poker run pending the water conditions. Its to hard to run with you in rough water. Beware of my new Jolly Cat that I will be running at the next event.
JEDNJONES
11-10-2010, 08:54 PM
I wouldnt be suprised turbo. You always beat me. Even on my own motocross track.
Jesse J
11-10-2010, 10:45 PM
yes, I used the stock drive dog on the new flex - its identical, I even ground off a flat spot for drive doggy to sink his teeth into. Being a 1/8" I should be able to fit it into a small flat rate box. Like I said, I don't mind if it will get you back on the water, hopefully for the weekend. If you pay as a gift (si senyor) then pm me your physical address. I will pop her in the mail tomorrow morning.
paypal is geohead73@hotmail.com
JEDNJONES
11-11-2010, 09:09 AM
Thanks Jesse. You have PP. I just couldnt find a long enough 4mm one to pop in anywhere besiseds hongkong. Ill use it temporary until I upgrade the drive system. So, you could have it back too if you want.
Jesse J
11-11-2010, 11:23 AM
need your physical address, don't think I have it still.
JEDNJONES
11-11-2010, 11:49 AM
Jesse, You have PM
Thanks for the help!
