View Full Version : Stuffing tube question??
hobie
10-07-2010, 03:52 PM
Can anyone tell me why I can't get a .150 Teflon liner in the stuffing tube. The .130 fits in, but then my flex shaft doesn't fit.
Am I missing something?
Is the stock one different somehow?
blackcat26
10-07-2010, 08:05 PM
Those liners can be kinda pesky. I have read that it may need to be stretched just a little to fit inside it. I hate teflon. I pulled mine out and installed brass and will never have to worry about it again. Done deal.
hobie
10-07-2010, 09:38 PM
OMG! yeah.... I was missing something alright! I never even thought about that. I will give that a go.
Thanks!
I'm thinking about how one would put brass in there?? Would you have to bend it to make it fit the curve?
blackcat26
10-07-2010, 09:53 PM
I used 2 peices. First the motor end, as far as it will go willingly and then the prop side until it meets resistance. I used 3/16 brass for it and scuffed up the OD of the new tubes and JB welded them in. Be careful to make them as accurate as possible as not to bind the flex. This was not my first choice of a replacement but I didn't feel like totatlly re-doing the stuffing tube.
ron1950
10-07-2010, 09:59 PM
quick question ....i am still using the origenal flexshaft the right handed one lol....seems it likes to spit grease into the boat at the teflon tube opening at motor....will it still do that if i put the left handed flexshaft in? or will it always do that lol...just a rookie question lol
blackcat26
10-07-2010, 10:07 PM
Maybe a little. Mine has a little splatter but that is easilly fixed. I have seen people on here cut a plastic bottle like a shroud and velcro in down as a sheild. Good idea I think.
hobie
10-08-2010, 07:36 AM
That is why I have no Teflon liner. I kept the backwards cable in, and sooner or later.... Blat, and you have no more cable.
If you have the new one, I'd be putting it in. Save you the hassle I've had to go through. That little Teflon tube is a pain to put back in.
Just my opinion tho!!!! :)
7500RPM
10-08-2010, 08:50 AM
Hey Hobie
I am working tonight if you want to drop by to get the parts we talked about last night. Then you
can install them and take it out for a Blast! :rockon2:
bigpapa
10-08-2010, 09:34 AM
hell i just converted mine to jeff wohlt .062 wire drive done deal and wks awsome
:banana::buttrock::banana:
hobie
10-08-2010, 09:46 AM
Hey Hobie
Well thank you sir! I will stop by after work.
Can't wait to see the difference!
7500RPM
10-08-2010, 10:20 AM
I work 5 pm to 9 tonight!
ron1950
10-08-2010, 11:45 AM
i want those hours...oh wait i dont work lol
7500RPM
10-08-2010, 12:14 PM
That's ok Ron, I don't consider it work, when you get to play with all the latest RC stuff! Got to love hobby shops!:banana:
ron1950
10-10-2010, 06:02 PM
just changed out my old right hand flex shaft over to the new one.....old one didnt have enough greese on it to stop any water from comeing in...sure does now lol.....
has anyone tryed a 440/3 blade on this boat? love the way it runs on the 642 but can always get better....
blackcat26
10-10-2010, 07:16 PM
Ron, I have not tried one but the 642 will be faster.
hobie
10-10-2010, 09:19 PM
I have been running a x447. Way more pick up off the line.
Well, I find mine runs way smoother with the 447.
ron1950
10-10-2010, 09:54 PM
no heat issues with the 447 hobie?
hobie
10-10-2010, 09:59 PM
Ron, nope, not at all. My motor and esc are temping at about 85 degrees or so. Wires and battery are closer to 100, but nothing to worry about as far as I know.
hobie
10-10-2010, 10:44 PM
Oh, and I'm also using a 60 amp esc, not the stock one.
