View Full Version : All about the roost!
Tony Vega
09-29-2010, 12:11 PM
Looking to change my prop for something that will throw up the biggest rooster tail. Not really looking for speed as we are limited in space but I am interested in throwing up the biggest rooster tail possible and splashing on lookers as I buzz by them. :) Any suggestions? Motor and esc are stock but I've added extra cooling to the motor. Running 2S Lipo.
Diesel6401
09-29-2010, 05:51 PM
A CF45 would throw a big tail, so will a CF48 but (WATCH) the temps on the 48 cause things can get out of hand fast. I would do the CF45. http://www.offshoreelectrics.com/products.php?cat=Carbon+Props
Darin Jordan
09-29-2010, 05:59 PM
You'll want to use a prop that has pointed tips, and has the trailing edge as close to 90-degrees to the hub as possible... This will throw the water off of the tips of the prop as lift, as opposed to throwing it aft, in the form of thrust.
Rounded tips with a flat trailing edge can work as well, as long as there isn't any spooning or cupping in them.
The Prather series of props, such as the 225 or 230, etc., would do it, as would the carbon props mentioned.
Have fun!
i use a x440/2 and it throws up a pretty good tail. i would say a good 5 or 6 ft
Chilli
09-29-2010, 07:10 PM
I hope your kidding when you say you want to splash on lookers. Not only does it cast a bad image for model boaters. There is the risk of an accident, injury and a lawsuit. Even if your doing it to your buddies.
Besides that....."You'll put your eye out kid!":bounce:
tunnelvision
09-29-2010, 07:41 PM
I run the CF45 on 4s. Check out my vid http://www.youtube.com/watch?v=kKPDOj7hFGg At about 1:10 in the video is pretty much the peak tail. Lot of fun this prop, run for about 4 to 5 minutes.
Brushless55
09-29-2010, 11:04 PM
This is one of my SV's running a S220 :thumbup1:
http://i703.photobucket.com/albums/ww39/filmmaker2009/038.jpg
AlanN
10-25-2010, 08:38 PM
The bigger the roost the less efficient you set up is.
Brushless55
10-25-2010, 10:03 PM
I do not agree with that
most of my fastest passes have had the biggest roost! :rockon2:
makin' waves
06-20-2011, 05:49 AM
:ThumbsDown01:
I always soak myself an others with a close to shore "buzz"
never lost an eye yet! :Peace_Sign:
Tone
makin' waves
06-20-2011, 05:51 AM
:iagree:
I'm using the same prop an its easy 5-6! :banana:
Tone
egneg
06-20-2011, 05:28 PM
Prather 225 back cut and severely detongued. Angle the strut or stinger up a couple of degrees from neutral.
