View Full Version : leopard motor
xxxrems38xxx
09-28-2010, 05:54 PM
what the maximum voltage for which the leopard 2200kv?
09-28-2010, 08:34 PM
The best voltage would be 4S/14.8 volts. More voltage than that will eventually destroy your ESC and likely your motor too. Even 4S is plenty of rpm. What model are you considering for this motor?
Jeff Wohlt
09-28-2010, 10:11 PM
Rated to 6S bit I certainly would not try it.
Make-a-Wake
09-28-2010, 10:30 PM
4s is plenty............thats 35,000 rpms unloaded...............about in SAW land basically.
xxxrems38xxx
09-29-2010, 01:21 AM
it's for a blackjack 26 with x642 2x2s 5000mah turnigy and 180A turnigy
09-29-2010, 09:21 AM
Well why didn't you say so in your first post? In that case, the best would be 4S/14.8 volts.
Make-a-Wake
09-29-2010, 09:24 AM
Yeah, that motor might overpower that hull just on 4s...........let alone 6.
