View Full Version : Crossing the brand name line
Diegoboy
09-27-2010, 09:36 PM
Will the UL-1 motor work under the OB cover, and will the stock Stiletto ESC handle it?
simo71
09-28-2010, 05:33 AM
Can't see why not. The stock ESC would be no issue as it is 60amp unit as well & you can program it timing etc unlike the UL-1 esc.
I'm fairly certain the stiletto motor is the same length as the ul-1 motor, I do not have a ul-1 motor on hand but the Proboat motor measures around 55mm long.
kevink
09-28-2010, 10:33 AM
Put the ul1 motor in the stiletto. Cover barely fits. It's just a bit longer, but fits.
Diegoboy
09-28-2010, 10:39 AM
Hey Kev,
Are you going to run the UL-1 motor in yours?
kevink
09-28-2010, 02:09 PM
Hey Kev,
Going to try to run after work this week. If not will run over the weekend. I will try to post a short video.
09-28-2010, 02:22 PM
You just got the boat and you already want to upgrade :w00t:
Diesel6401
09-28-2010, 05:50 PM
Damage is already done steve, I just bought the stilleto motor off of him, Its going in the MG. Maybe a nice little pb upgrade over the BJ power already in the mg. Not sure if I wanna keep it all PB and buy the stilleto esc or just slap a different esc in it. Prob a seaking or swordfish 120
Diegoboy
09-28-2010, 06:42 PM
Ya. I'm bad.
HazeGry is polishing the OB... WOW!
Brushless55
09-29-2010, 12:08 AM
We want a report of how well this motor is going to work in this hull!
IMO, this F1 should come with a higher kv motor
ron1950
09-29-2010, 06:28 AM
a friend of mine polished the outboard and wow it will shine like crazy.....mirrior anyone?
Darin Jordan
09-29-2010, 10:51 AM
Higher KV = Less Torque... And less runtime. Remember, this is targeted to a sport market, with racer appeal. Racers are expected to want to upgrade, change, etc... Plus, this hull is a little heavier than the VS-1. I am not expecting a miraculous performance increase with the Ul-1 motor, honestly. You'll need to prop it way down... < 40mm in my opinion to make it work.
By the way, the stock Stiletto motor is actually 1885KV, not 1800... or about 31,000RPM on 4S...
Brushless55
09-29-2010, 02:45 PM
I'm thinking more in the lines of rpm over torque for this hull.. :thumbup1:
Darin Jordan
09-29-2010, 03:12 PM
Prop accordingly, and let us know how it works out. :popcorn2:
Brushless55
09-29-2010, 03:16 PM
I'm not the one with the UL-1 can sitting on my Stiletto :biggrin:
Diegoboy
09-29-2010, 03:39 PM
I am! Woo Hoo!
PB motor = 53mm long
UL-1 motor = 56mm long
I hope that adds at least a little back to the missing torque. :olleyes:
Darin Jordan
09-29-2010, 04:16 PM
I am! Woo Hoo!
When you pull these motors apart, you'll find that the stator and rotors are exactly the same length... only the cans are different.
I've burned them all up and have torn them all down. :thumbup:
Doug Smock
09-29-2010, 04:52 PM
Darin my brother. Ya got to learn not to burn. lol J/K
Danny I'm glad to see have a tunnel. Your going to have a blast with it next year!!
Doug
Darin Jordan
09-29-2010, 04:53 PM
I burn... so you don't have to! :Peace_Sign:
Doug Smock
09-29-2010, 04:56 PM
:laugh::laugh: Thank you sir!
Rumdog
09-29-2010, 05:01 PM
hippie!
Darin Jordan
This statement is true for the PB BJ26/MG motors vs the UL-1...
The Stiletto motor is actually shorter inside by about 1/8". 1885KV, but less mass yet, so torque suffers.
Diegoboy
09-29-2010, 05:56 PM
Doug
Doug, I also got a cobra tunnel in custom blue/yellow coming. I picked up an OS lower unit from my LHS for that. I'll be needing all the tunnel gurus advice for that one...
:bowdown:
Diegoboy
09-29-2010, 06:00 PM
The stiletto will be my spec, and the cobra willbe my P
hazegry
10-01-2010, 10:14 PM
danny your outboard is done
kevink
10-02-2010, 05:45 PM
Just got back from running with the UL-1 motor. With Grim 42x55, I barely had it up to full throttle. Temps were great after 3 minutes. 88 degrees on the motor and esc. Too windy today to be comfortable at full throttle.
Diegoboy
10-02-2010, 10:37 PM
nice report, even on a 42mm prop. SWEET
Brushless55
10-02-2010, 10:38 PM
How do you think it did vs the stock motor?
kevink
10-02-2010, 11:17 PM
When I got the stiletto, I was seriously disappointed with the lack of speed. Now with the ul1 motor, I am timid to hit full throttle. There is now a serious increase in speed. So much that I will probably go down to a smaller prop. Expected the temps to increase. Temps went down a bit but that is probably due to the decrease in water temps. The last time I ran the stock motor the water temps were around 98 degrees. Today's water temps were around 80.
Today's run was with the stock esc but installed 5.5mm plugs and hyper performance flex. The stock cable unwound because it was in contact with the outboard housing at the motor end. Corrected by opening the hole just enough to clear the flex shaft. Check the alignment as Darin suggested. Also, if you use the ul1 motor the esc rev limiter with no load prevents the motor from operating out of water.
Brushless55
10-03-2010, 12:57 AM
Right on man!
sounds like a great direction with this hull :beerchug:
Diegoboy
10-03-2010, 08:16 AM
Awesome, my UL-1 motor should be here Monday afternoon, I can't wait!
Brushless55
10-03-2010, 09:27 AM
My prediction.. :spy:
Having the UL-1 powered Stiletto will be a combo to beat
I believe with the right prop this setup will be faster in the turns and faster down the straights, and I bet runtimes will not suffer. :rockon2:
The more I think about it the more I want one :thumbup1:
Diegoboy
10-03-2010, 09:49 AM
My OB is polished to a mirror shine (Thanks HazeGry), My steering linkage is slightly modded to make hatch taping easier, I need to get down to business on the ride pad & OB mods before the motor gets here!
hazegry
10-03-2010, 03:53 PM
take pics when you get the outboard back on the boat danny I want to see how it looks.
Diegoboy
10-05-2010, 10:08 AM
I need 1/4" brass tube to do the OB mod (and a stuffing tube for the Z-27) Hobbytown is OUT and Debbies RC World is closed on Tuesday :mad:
Diegoboy
10-06-2010, 10:34 AM
I can't believe my entire build process of 2 boats has come to a hault due to the lack of 1/4" brass tube...
Darin Jordan
10-06-2010, 10:43 AM
That does suck! WTH!!?? Have you checked your local ACE hardware or ??? Our ACE and also McClendon's Hardware both stock the full array of K&S tubing...
Diegoboy
10-06-2010, 11:01 AM
Thanks for the tip, I never checked in a hardware store
Ub Hauled
10-06-2010, 12:56 PM
LOL
I hate when you are in a groove and some tiny little Monday detail stops the whole thing...
ACE does carry a good assortment of tubes, more then fricking Hobby People does... I buy from them all the time... not sure how the prices compare but the difference will be negligent....
I also do wanna see the polished lower end... Darin, I am surprised you have not done that!!! I know you have done it polishing to some fins and they look great...
I am not sure about the weight difference between the VS1 and the Sti... but I tell ya that the VS1 was a tad light with the UL1 motor on ... maybe this bit of extra weight is just what the Doc recommended...
Diegoboy
10-06-2010, 08:48 PM
OK,
Here's the polished OB. Please keep in mind that it's not yet assembled...
http://www.diegoboy.com/misc/100_4051-sm.jpg (http://www.diegoboy.com/misc/100_4051.jpg)
Click for a larger vew
ron1950
10-06-2010, 08:59 PM
are u going to clear coat it of polish it after every run? looks great but more work then i want to do on it lol
Diegoboy
10-06-2010, 09:05 PM
Thanks Ron, I think it looks great too!
hazegry
You can clear it I have cleared brass I have polished and its held up well a quick buff with aluminum polish takes less than a min and will keep the ob looking good. Ron if you want it done you can pm me and we can talk about it. The process takes me a few days I dont have fancy equipment but it looks so much better polished up.
ron1950
10-06-2010, 09:51 PM
thanks but i am good with it stock...i know they are strong as i hit a fish or turtle under the water today....knocked the angle of the motor to max positive angle but didnt even dent it at all.....boat flew up about 6 inches and kept going...
kevink
10-12-2010, 04:51 AM
Here's a couple quick clips of the Stiletto with the UL-1 motor and grim racer 42x55 prop. Temps were good at around 90 on both esc and motor after 4 minutes. Finally a calm day to run.
ipA87LMq3FU
ULwDPpqXkNA
Brushless55
10-12-2010, 03:15 PM
Looks great! :banana:
Darin Jordan
10-12-2010, 03:17 PM
Does look great... it's almost as fast as mine is with the stock motor... ;)
Brushless55
10-12-2010, 03:19 PM
and with the proper prop it will be faster! :rockon2:
kevink
10-12-2010, 03:21 PM
I know, replaced a stock motor, but for some reason, the stock motor, with both the stock and 42x55 props, would not spool up very fast at all. All esc settings set identical to yours, but still no performance. Curious if the hyper performance flex made any difference. Had to readjust for the extra length, but now runs great with different motor. Any ideas?
kevink
10-12-2010, 03:23 PM
Open to suggestions for more props
Darin Jordan
10-12-2010, 03:39 PM
Actually, the 42x55 with some tweaking will be very close. It needs to have some pitch added to it to be where it will really shine, but also have some load taken off the prop. If you back-cut it a bit... start at .030" or so, and start pitching it up a little at a time, I think you'll get better.
Remember, this boat is a bit heavier, being a RTR production boat, and not a purpose built race boat, so it's not going to work the same as a lighter VS-1 or Cobra or ???...
ron1950
10-16-2010, 10:40 AM
guess i have to start saveing my walking around money for a ul-1 motor now....darn things seem to be harder to get then hens teeth....not one responce in swap shop for a used one.....
Brushless55
10-16-2010, 10:52 AM
They like Gold Nuggets! :laugh:
forescott
10-22-2010, 08:11 PM
Just got a pair of stilletto O/B's for a 31-inch proboat cat.(see avatar) Bought the outboards without motors because of limited funds. Looking to get the ul-1 motor or sv-27r motor to put in em. Gonna run a single 5000mah 4s 30c pack per O/B. Do you guys think the 2030kv's will run cool enough or should I get the 1800kv's. I would just buy the stilletto motors but they are 100-bucks a piece, so I'm looking to save a few bucks with the AQ motors.
Brushless55
10-22-2010, 08:20 PM
UL-1 all the way!
They will share the load and do very well with your build..
Doby
10-22-2010, 08:22 PM
SV motors were 34 bucks at Tower last week. (the blue ones)
forescott
10-22-2010, 08:39 PM
I was considering those too. I thought I read somewhere that they were actually less than 1800kv. Plus I had issues with the endbell coming loose on my old sv, so I decided against them. Thanks for the info on the sale though!!
kevink
10-22-2010, 08:56 PM
Darin, thanks for the prop suggestions. I need to learn more about prop mods. Any credible resources to learn about prop modifications? Not a whole lot of resources where I live.
Also, thanks Diegoboy for fixing the links to the vids.
ron1950
10-28-2010, 06:15 PM
ok ul=1 motor on the way...now will it bolt right on old stock stiletto motor mount...what mods will i have to do now with the new motor? have the 42x55 all ready and will maybe send it ti chuck for cutback and some pitch.......thanks
Darin Jordan
10-28-2010, 11:52 PM
Should bolt right on. You'll need to make sure you install the coupler at exactly the same distance from the endbell. Otherwise, it should be a bolt-on...
ron1950
10-29-2010, 05:44 PM
thanks darin....damed thing didnt show up today lol have to wait for monday delivery now ...kinda cool anyway to be at the lake.....
forescott
10-29-2010, 07:54 PM
Just installed a ul-1 motor in one of my stilletto outboards. Motor and mount holes are a tad off. Start all 4 screws, and alternate tightening them a few turn each until tight. It fits, just a little snug! Also picked up some hyperformance flex cables that look much better and straighter than the stockers. Slightly longer than stock, so the motor coupler has to slide all the way up the motor shaft. It looks like a good fit as well.
chummer
10-29-2010, 08:42 PM
If I remember correctly it was Darrin that tested these and he said they were in the 1500kv range. That's probably why these things can swing a good sized prop.
forescott
10-29-2010, 09:54 PM
Yah, its actually posted that way in the ose store.
ron1950
11-01-2010, 05:52 PM
i got the new motor and as usuall the holes dont line up on the ul-1 motor tryed all the different combos....so its held in with only 2 bolts ...hope it holds lol.....any suggestions? read forscott's thread about being a little off but mine seemed a lot off
Diegoboy
11-01-2010, 07:02 PM
Hmmm... mine llined right up, no issues...
...but 2 bolts are all I ever use
ron1950
11-01-2010, 08:03 PM
cool glad to hear it...did all 4 line up? i tryed it every way i could and only 2 holes ever got even close to lining up......
Diegoboy
11-01-2010, 09:05 PM
Just a perspective, do you use all four bolt holes when you mount your motor in a cat, hydro, or Vee?
Only 2 ever line up for me, I have really never tried to use all 4. I don't remember if the stock motor used all 4 holes or not.
ron1950
11-01-2010, 09:08 PM
sounds good to me diego.....only use 2 screews in my tc-5 car motors so guess we are good to go...i dont have the experence u do at all in boats
Diegoboy
11-01-2010, 09:35 PM
I really can't remember how many screws were holding the stock motor. Can anyone remember how many?
GP73
11-01-2010, 10:17 PM
Stock is 4, other motors are 2 screws.
ron1950
11-02-2010, 02:20 PM
wonder why everyone says just bolt it right to the stock mount....i know i am too dumb to figure it out only got 2 screws to line up lol
Darin Jordan
11-02-2010, 03:12 PM
Some motors don't have a symmetrical bolt patterns. Not sure about the AQ motor.
GP73
11-02-2010, 04:55 PM
Because it does, with only 2 bolts... :banana:
ron1950
11-02-2010, 04:58 PM
yeaaaaaah i am smart again ...lol...thanks gp
ron1950
11-14-2010, 08:20 PM
i am sooooo impressed with the ul-1 motor in the stiletto.....it litterly flys now.....rides on last 2 inches of sponsons and prop...still need to tune the nose down slightly but wow what a rush now compared to the stock motor.....
Brushless55
11-15-2010, 01:12 AM
Sweet..
what prop are you running?
ron1950
11-15-2010, 05:08 PM
i think its a x 640 detounged i got it from a friend and it had 38 written on the blade so thinking its 38 cm or mm whatever it is lol now? not sure but i know it works lol
Diesel6401
12-03-2010, 02:22 AM
Just curious if anyone has thought of running a ammo 2600 in this on 3s/4s setups with a smaller diameter prop of course, like a x437/3. Just wondering. I'm really interested in this boat... Never owned a tunnel, but when I do this would be it. Also curious on how this stacks up against the UL-1 power VS1's with this running ul1 gear of course. Just wondering.
ron1950
12-03-2010, 06:37 AM
pick up a stiletto and a vs-1 and see the difference in weight.....all things considered id go vs-1 if i had it to do again.....never tryed any other motor then the ul-1 in my stiletto.....it runs well now but still not into the 40's ....think i need to adjust the motor angle again and maybe a new prop as it runs very cool now with the 640
Diesel6401
12-03-2010, 03:30 PM
I guess you mean the Stiletto is a lot heavier? Maybe higher KV like the ammo isn't the answer, you think maybe a BJ motor on 4s/5s with a bigger prop may help?!? Like I said I'm really eyeing this up. I love the BND idea.
GP73
12-03-2010, 04:07 PM
Yes, I've tried a Feigao 11L (2300Kv) and I didn't see a great improvement in speed, that was with a x437/3. But I did see smoke coming out of the stock ESC and later a Suppo 70A... :lol:
I've also tried a Turnigy 500 1800Kv outrunnner with the same prop and it was better than the Feigao.
I would stick to the stock 1800Kv or Ul-1 and play with the prop size/pitch as suggested by Darin. I'm wondering if the Y537/3 is worth a try too.
Darin Jordan
12-03-2010, 04:09 PM
DING-DING-DING-DING...
If you guys have paid any attention at all to what I've been saying, and also to my MG testing EagleTree Data... you'll see that simply going up in KV isn't the answer... You go up in KV, but leave motor dimensions the same, you are gaining RPM at the expense of torque. The end result is about the same amount of power, laid down in a different manner.
I have solid data showing a STOCK motored MG racing in the 45-47mph range. It's done with prop and setup. Going to a 2030KV UL-1 motor on a 6+ lbs boat (STLO) and having to run a tiny prop to keep it from overheating is the wrong direction. The stock MG 1500 motor with a 42-25mm prop with around 4.0" of pitch (last .250 or so of the blade) will have this boat flying, and not overamping it. Will have more grunt out of the turns, and through the turns. Setup will be a little more critical, as the added pitch can torque the hull more, but the setup would fly.
NOW, if you want Higher KV, you will really want to go with a LARGE motor... the 1515 1Y or something with more mass, longer rotor, etc.
I tried like CRAZY to make the Stiletto light, but it's a bigger boat, with cool features, and a production boat to boot. Only so much weight savings was possible and still keep it strong enough to survive the thrashing you guys will put it under! ;)
So, my recommendation would be to either upgrade to a 1/8th scale buggy sized motor, or a 1515 series Neu or similar. I have a Losi Xcelorin 1/8th scale 2100KV buggy motor that simply ROCKs on mine... and I also was thinking of trying a Castle 1512 1800KV or similar. ESC changes will be required, of course.
If you want to stay P-Spec legal, then I'd suggest you try the 1500 MG motor, or the 1800 STLO motor.
Diesel6401
12-03-2010, 04:26 PM
Very good sir. I just started thinking really hard about this so haven't had a chance to review everything you said darin which is Y i may have missed your information on that, or I read it and forgot I read it which is always possible. I have a spare BJ/MG motor and with the stock 60 amp esc may be nice bit of head room for playing around with some props. I also have a NIB CC 1512 1800kv which I could use. Darin I imagine the motor cover would work with the BJ motor and not the CC motor, is that correct? Also would the 1512 with the jacket fit OK? Never owned a tunnel hull, getting kinda excited.
GP73
12-03-2010, 04:37 PM
Wouldn't that defeat the purpose though? More mass=more weight on the boat? :confused2:
Maybe a Leopard 4060/1900Kv or 4065/1800Kv are a better option? If we are to believe the mfg specs they are 295g and 311g respectively, which is less than the 1512 (370g) and the 1515 (424g) .
Not sure how they compare in performance though.
Just for reference, the stock motor is 206g.
Darin Jordan
12-03-2010, 04:52 PM
With this type of power... weight to KEEP the boat on the water becomes more of an issue... :thumbup:
As an example... I put a Losi Xcelorin 2400KV motor with a Hydra 240 and a lightly massaged X440/3 on my Stiletto and attempted a 2-Lap record run... Need to do a little more tuning, because the boat was BALLISTIC and just flew off the water on the backstretch at a speed I'd estimate to be approaching mid-50s.
Diesel... I had to mod the motor cover to fit around this larger motor, but it looks pretty cool when done, don't you think?? :rockon2:
Diesel6401
12-03-2010, 05:00 PM
I would say cool is an understatment and bada$$ is more fitting! Amazing as always.
GP73
12-03-2010, 05:02 PM
Good to know! :biggrin:
Care to share some of your EagleTree data? What kind of amps are you seeing with the Xcelorin?
ron1950
12-03-2010, 05:47 PM
darin u keep teasing us with that new motor when do we get to see some video ? also what tuning do u need to do to it? just motor angle and hight or what?
Diesel6401
01-09-2011, 02:27 PM
Darin looks like I'm getting ready to pull the trigger on this thing. Another quick question I know you had to mod the cover to fit over the motor, but I wanted to just make sure and verify the water jacket on the 1512 will fit under that cover. I can't tell if you have any water-cooling on the losi motor or not.
Ron you still looking to buy a Stiletto 60amp esc?
