View Full Version : Hyperion Duo II question
JimClark
09-25-2010, 02:51 PM
Ok just bought aHyperion duo II. I have a 12 amp power supply and most likey will never get above a 4s 5000mah battery.
Didn't think about the powersupply I am onlu used to haveing 50Watt chargers but this beast is 360 watts 180 per side.
Can i get by on the smaller power supply?
jim
egneg
09-25-2010, 02:59 PM
If you limit each side to 5 amps you will be fine.
Raydee
09-25-2010, 04:20 PM
Yeah they can be power hungry. I use a 50 amp at home but at work I used a 12 amp one time and forgot to limit the amp draw in the DUO and actually burned up the power supply charging two 6s 5000mah cells at the same time.
HOTWATER
09-26-2010, 10:46 AM
I use a Duo II with a 12 A computer power supply...I charge 4S 5000 lipos with it...works fine!
BHChieftain
09-26-2010, 10:05 PM
If you are looking for a good AC power supply for the hyperion, I use this one and it works great.
icharger p350
http://www.progressiverc.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=38&category_id=2&option=com_virtuemart&Itemid=1
This will provide max power for both channels-- useful if you ever want to charge above 1C (for example, some hyperion lipos can be charged up to 5C, but you need a lot of juice for that).
Chief
oscarel
09-27-2010, 03:07 PM
A cheaper alternative would be a Dell 500CB power supply from ebay for about $20, they supply 41A at 12V.
http://cgi.ebay.com/Dell-Poweredge-2650-500W-Power-Supply-DPS-500CB-/110509091012?pt=COMP_EN_Networking_Components&hash=item19badae8c4
Here is the link for getting it to work, requires shorting 3 pins together. I hooked 2 pins to one side of a switch and the 3rd to the other and it works perfect. http://www.rcgroups.com/forums/showthread.php?t=1248037&highlight=dell+500cb#post15143837
JimClark
09-27-2010, 03:10 PM
Do you have one? Can you tell me the dimensions? They look huge on the ebay pic
oscarel
09-27-2010, 03:15 PM
Yes, I'll check dimensions when I get home.
oscarel
09-27-2010, 03:25 PM
Found these dimensions online 14 1/2 * 3 * 2 1/2. I bought a little project box from Radio shack and put 2 sets of female banana jacks in it with a switch and mounted the power supply under my work bench so it's out of the way. It is a little on the loud side and it's in the garage, but for $20 it can't be touched.
HOTWATER
09-27-2010, 05:20 PM
Yep...I got mine for around $20 also, but I like this one much better. Mine is a 13A and does not have a fan...this one is 41A with a fan! Nice find!
-Kent
oscarel
09-27-2010, 05:53 PM
The dimensions are about right, it's about as long as 2 ATX power supplies. Thanks Kent! The one in the pic is a spare I bought just incase the first one was defective. I've been using the first one I bought for about a year with no issues at all.
JimClark
09-27-2010, 11:49 PM
So any tricks to wire one of these PS's up?
oscarel
09-28-2010, 08:36 AM
Very simple. Wire 2 of the pins marked Y together and connect to one side of a switch. Wire the remaining pin marked Y to the other side. I used pins from a servo cable and they slide on and so far are staying put.
N N N N N Y
N N N N Y N
N N N Y N N
N N N N N N
