View Full Version : Mini Rigger
Basstronics
09-19-2010, 07:50 PM
Ive been wanting to do a rigger for awhile now. Just not familiar with them and whats good.
After the reading I have done I would like to build a scaled down version of the JAE.
I have downloaded the DXF and scalled it down by .6666"
This is giving me:
20" overall tip of sponson end of tub
12 11/16" sponson to sponson
2" wide x 18 13/16" x 1 3/8" tub
Sponsons 7/8" wide
Im thinking this might be a good start point.
Power would be:
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11172&Product_Name=Turnigy_450_H2218_Brushless_outrunner _3550KV
or
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9021&Product_Name=Turnigy_Typhoon_450H__2215H_Heli_Moto r_3550kv_%28450_class%29
Think this is going in the right direction?
If anyone has hull ideas/plans, etc I have CAD (AutoCAD). I also have 3D CAD and I can do complete 3D models...
Diegoboy
09-19-2010, 07:57 PM
What cell count will you use?
Will it be laser cut, or manual cut?
Basstronics
09-19-2010, 08:06 PM
Im thinking 3s, 427 prop?
Im still green in the hobby :) But I have goals.
It will be hand cut and home made hardware.
Diegoboy
09-19-2010, 08:13 PM
Did you scale down the 21G2??
Basstronics
09-19-2010, 08:16 PM
Yes sir.
Thats what the measurements came to given the scale.
I think the height needs to be adjusted larger and add a little more on the width of the tube- maybe another 1/8".
It was just a quick select all and scale.
If things are sounding good for the seasoned I will get my motor and get a full 3D model whipped up.
Diegoboy
09-19-2010, 08:29 PM
I just learned that the 21FE tub is narrower than the 21G2. SO you scaled down the larger tub design!! Good job
Diegoboy
09-19-2010, 08:30 PM
I like the 1st motor you linked to
Basstronics
09-20-2010, 06:24 AM
Eh, cool!
The width didnt seem to bad. I think it will hold most batteries I would want to use.
SweetAccord
01-25-2011, 06:50 PM
I'm digging these:
http://www.mhz-powerboats.com/mhzpowershop/artikeldet.php?proid=56&sid=5a0cdd07a9c8253d350c93876ed3893f
wparsons
01-27-2011, 02:56 PM
I started on one, but I'm going to have to re-design/build the tub. As it stands now it'll barely fit a 2040 motor with cooling jacket. I basically designed it to fit a 3s 2200mah pack, but forgot to even consider motor size.
The bigger tub will be made to fit a 450 outrunner with water cooled mount.
martin
01-27-2011, 04:03 PM
The first motor you show the red one is the more powerful out of the 2. I run one of the other motors, The Typhoon in 3450kv at times. It has much thinner wires coming from the motor so they do get a bit warmer running on 3s lipos. The amps on the Typhoon is lower than the red motor. I think youll find the red one the better option, Their again these little 450 size motors are so cheap you can try both. Thats the fun of these mini / micro boats you can buy an assortment of motors to try with varying kv & have fun developing them for very little money. Thanks Martin.
wparsons
01-27-2011, 04:09 PM
I'm running the 3200kv turnigy one in my jet sprint and it has been super reliable.
Alexgar
01-27-2011, 04:27 PM
i think your prop is to little on my 3s renegade rigger(16") i run a 531 and its pretty quick the motor is a 2600kv outruner
martin
01-27-2011, 05:30 PM
Im running a 450 outrunner 3600kv on 3s with an Octura x435 sharpened & balanced prop, Although this is in a 15" deep v mono. Thanks Martin.
Jim Bob
02-04-2011, 08:55 PM
I would suggest a little wider than 2" on the tub. I will post pictures when I get the electronics in my new build(waiting on paint). It is 16.5" long x 2.125 wide x 1.25 high. It is a tight fit. The rear sponson tube does not go through the tub in order to allow room for batteries.
40633
40634
wparsons
02-04-2011, 09:16 PM
On the one I'm working on, I moved the rear sponson boom back to allow a 3s 2200mah pack to fit between the booms.
Any more details on yours? Is it a scaled down JAE with a bigger tub as well?
Jim Bob
02-04-2011, 10:29 PM
Yes it is. I intend to run a 3s 2650 pack. I run 2150 zippy packs in my old rigger and only get about 4 minutes runtime and the battery would get warm, so I wanted to go with a litttle larger battery. In order to keep the CG where it needs to be on a 16" boat I needed to be able to run the battery close to the motor. The mounts I made for the rear are just as stable as the front boom, which is one piece. I also ran into an issue with putting the collars on the front boom, so I secure it with one screw through the bottom of the tub and front boom. Here are some photos.
40638
40639
40640
40641
wparsons
02-05-2011, 05:06 AM
What motor mount and strut are you using? Where'd you get the hatch?
Jim Bob
02-05-2011, 12:07 PM
I made it all. Hatch is 1/32 plywood.
Brushless55
02-08-2011, 02:55 AM
Oh man!
A mini rigger that I could run my small 3s 2200mah packs in would be killer!:beerchug:
badag98
02-08-2011, 08:08 AM
40638
40639
40640
40641
What kind of speed are you getting out her??
Jim Bob
02-08-2011, 10:29 AM
Have not run it yet, and don't have a wy to tell. No gps or radar.
Brushless55
02-08-2011, 04:05 PM
I want one! :w00t:
