View Full Version : Imax b6 charger
Woodz
09-17-2010, 02:59 PM
i have just got my 4s 3000mah lipo and went to go and charge it and it gives me a low voltage error any1 have any exsperience with these chargers?????:help:
Alfa Spirit
09-17-2010, 06:33 PM
Which voltage?
Power supply or LiPo voltage?
Woodz
09-18-2010, 01:39 PM
i dont know i select balance on the on charger and 2 seconds later the charger says "INPUT VOL ERR" but it charges my 3s packs???????
sailr
09-18-2010, 01:44 PM
Your power supply isn't supplying sufficient volts or amps for the 4S packs. What amps are you trying to charge them at?
Woodz
09-18-2010, 01:45 PM
3 amp but i turn them down and try to balance them at 1 amp but stil dont work?
sailr
09-18-2010, 01:46 PM
The message you are getting is for the power coming into the charger. What sort of power supply are you using? Hook the charger up to your car battery and see what happens.
Woodz
09-18-2010, 01:47 PM
k ill try and im using a 12 volt mains?
sailr
09-18-2010, 01:49 PM
yep, 12V input to the charger.
Woodz
09-18-2010, 01:52 PM
just put it on car battery and its charging at 1 amp thnx so much
sailr
09-18-2010, 01:53 PM
Yep. You need a new power supply if you want to charge off 110V!
sailr
09-18-2010, 01:55 PM
You should be able to charge off the car battery at much higher amps.
I would suggest you get this charger. It's a bargain. Works GREAT and is both AC and DC. Best deal on the planet and cheaper than a decent power supply!
http://www.hobbypartz.com/thac6smbachw.html
