View Full Version : FASTECH Performance TRICKS?
b.mcdaniel.2009
09-17-2010, 02:02 PM
Just got my formula fastech and im running (2) 2s 5000mah 35c lipo's, stock motor/esc and prop. Does anyone know if there's some tweeks i can do to run a little bit faster like adjusting the hardware on the transome? Let me know guys .THANKS
Oh also have 3s 4400mah packs on the way!!
JEDNJONES
09-17-2010, 04:47 PM
First thing to do is order an Octura X642 prop from here on OSE. Balanced/Sharpened. Trim the boat up out of the water to where its still stable enough for you. Bump timing to hi (need programming card) Also here on OSE. And she will reliably run 35 to 40 mph all day long with low temps. I wouldnt go more than 4S with that ESC.
Jerry
lectriglide
09-17-2010, 05:49 PM
Do some reading in this forum. There are multiple things you can do to make it perform better.
This thread identifies a couple major ones. http://forums.offshoreelectrics.com/showthread.php?t=12302 :biggrin:
Diesel6401
09-17-2010, 06:21 PM
I hope you don't plan on running 6s on stock esc...
b.mcdaniel.2009
09-17-2010, 09:16 PM
What not a good idea on 6s? What about adjusting the prop shaft angle up or down, or the adjustment on the transom of the boat?
Diesel6401
09-17-2010, 09:21 PM
Stock esc is rated at 21v, 6s would be 22.2v. Although some of done it I would advise against. Run 5s instead, just make sure you disconnect the bec first and change the crappy stock 3.5mm bullet connector on the motor & esc to 5.5mm bullets. Also if you haven't done it yet dump those deans connectors ASAP.
BHChieftain
09-17-2010, 11:35 PM
One other thing to consider-- there is no way to waterproof the hatch, so if you get too crazy with speed and turn it over, it will flood bigtime...
Good news is so far my son has not been able to flip it, running 4S1P on x442, moving to x642 in a few weeks... darn stable hull...
Chief
b.mcdaniel.2009
09-18-2010, 07:38 PM
What do you mean 5s?
lectriglide
09-18-2010, 07:48 PM
5s, like a 2s lipo and a 3s lipo in series.
b.mcdaniel.2009
09-18-2010, 07:55 PM
oh okay thats what i thought.Thanks
b.mcdaniel.2009
09-18-2010, 07:58 PM
so to make sure im following you, use a 2s and a 3s pack that are the same? and isnt my fastech wired in a series from the factory
Diesel6401
09-18-2010, 08:14 PM
Yes it is wired series from the factory. Take a 3s lipo and plug it into on side and a 2s and plug it into the other side. Packs the being the same means same "c" rating, mah and I try to use same brand. They should be identical besides the different voltages. Disconnect the bec (red wire) from the esc connection that plugs into the rx. Did you dump those deans connectos and change over the 3.5mm motor & esc connectors? I wouldn't run 5s until those things are done.
b.mcdaniel.2009
09-18-2010, 10:28 PM
Why get rid of the deans? I've always ran deans for years in my trucks and cars, but never had a boat with this amount of power LOL! And im picking up those 5mm connections you said when the hooby store opens tomorrow!!!
Diesel6401
09-18-2010, 10:45 PM
Cars & trucks do not have near the amp pull boats due. Deans are limiting you, and so are the stock 3.5 connectors.
b.mcdaniel.2009
09-18-2010, 11:15 PM
so what connections do you recommend?
lectriglide
09-19-2010, 10:52 PM
5.5mm bullets http://www.offshoreelectrics.com/proddetail.php?prod=ose-55bullet
Diesel6401
09-22-2010, 12:19 AM
BINGO :thumbup1:
Make sure you change all of them. When it comes to the power side of the esc make 1 female and 1 male. When you go to power the boat take batt 1 red wire connect + to esc connect batt 2 black wire to - of esc after that take batt 1 black wire and plug it directly into batt 2 red wire. You just created a series circuit and you don't need any jumpers or lame deans. Hopefully that makes sense.
b.mcdaniel.2009
09-22-2010, 06:56 PM
lol kinda. Can you send me a picture of what your talking about.
Diesel6401
09-22-2010, 07:17 PM
At work right now, so I can't take a pic but maybe this ms paint helps for a series circuit. This (http://www.offshoreelectrics.com/wiring.php) can help also.
lectriglide
09-22-2010, 10:20 PM
Here's what I do, works great. I think its the same thing Diesel is explaining - see post #157 complete with pic :thumbup1:
http://forums.offshoreelectrics.com/showthread.php?p=113595
Diesel6401
09-22-2010, 10:34 PM
Yup it's the same :thumbup: easiest way to do it. To insure I do not short the battery I hook the esc connections first and leave the battery 2 battery connection last.
b.mcdaniel.2009
09-22-2010, 11:32 PM
ya thats how my fasteck is wired.
b.mcdaniel.2009
09-22-2010, 11:51 PM
okay gotta ya on the wiring. Had to see it dont to get it.Thanks a ton.
