View Full Version : Turnigy 90A esc programming help!!!
Karfrik
09-15-2010, 11:58 PM
Tried the manual Tx procedure and many others but throttle doesn`t hold right.I have a Tactic 2.4 Tx/Rx.HK even doesn`t recommend ussing the manual Tx programming.Anyone here have done it sucessfully? or do i really need to get me their programming card?.....Thanks,...Al
Graeme
09-16-2010, 01:17 AM
I had some issues with mine but I re bound the rx and problem solved programmed no problem.
Karfrik
09-16-2010, 10:08 AM
What you mean by rebounding the receiver? can you explain a little more?..thanks fpr replying .........Al
JMSCARD
09-16-2010, 10:11 AM
push and hold the bind button on the rxr while you turn on the transmitter.... well I think thats how i remember binding the tactics.... pretty darn sure anyway.
Karfrik
09-16-2010, 10:33 AM
Just in case,my problem is not binding the Rx with the Tx.Its getting the esc to work properly.
So in doing so as you explained here i`m guessing packs should be connected first.Then press the tactic binding button and then turn on the transmiter?...did i get it right?...thanks,...Al
