View Full Version : BJ BL Esc
domwilson
11-06-2007, 12:22 AM
It looks like the ESC can handle 16 cells. What do you guys think?
By the way, Will this fit an Octura Prop with a 3/16" bore? I mean the prop shaft, not the ESC.
http://www.horizonhobby.com/Products/Default.aspx?ProdID=PRB3309
Nope. They use a 1/8th shaft.
RCprince
11-06-2007, 07:18 AM
The BJ fits any 3/16th hub size prop once you use the Brass bushing, I ran mine with 18 cell and yesterday morning I ran it with a 6s 4500.....needs a little more weight though, it was a plane, it starts to go airborne and flip backwards at 52(gps).
Witch is it? Did you 18 Nimh or 6s lipo?
Is that a 3mm shaft?
RCprince
11-06-2007, 10:59 AM
I used both...I borrowed one of my cousins 6s for a test run it performed well, just a lil' to light in the bow for the speed, next I'll try 2 6s in parallel.
RCprince
11-06-2007, 11:02 AM
On the shaft I did like what diegoboy did and ran a .150 octura flex shaft kit...works flawless, with no vibration unlike the universal joint. and on the shaft , it's either a 1/8 or a 3mm which ever is bigger, just not a 4mm.
