View Full Version : fiber glass help
kinsei
09-11-2010, 01:28 AM
hi all i got my boat (not from ose btw), but there is a long crack between upper and lower hull in the front
how should i repair this? thanks in advance
JimClark
09-11-2010, 03:21 AM
send it back
kinsei
09-11-2010, 04:05 AM
thanks but thats the problem... as i am from hongkong sending it back will cost me another 90USD!
any easy and sure way to do this??
westbeach
09-11-2010, 07:08 PM
Is the hull fiberglass with gelcoat finish?
domwilson
09-11-2010, 07:27 PM
I would contact the seller to see if they might pay shipping as well. Send them a pic of the damage. Many sellers will work with a customer.
If they won't work with you, then simple epoxy should fix this.
kinsei
09-12-2010, 02:46 AM
sorry this is my first ever fiber boat.. and the seller told me to contact horizon
westbeach: gelcoat do you mean the thing that fallen off the cab?
dom: simple epoxy do you mean the thing that held the screw ring? can you give more detail?
Flying Scotsman
09-12-2010, 03:01 AM
It is a fibreglass hull with a paint finish, was the box damaged when you received it. The dude you purchased it from is MIA. Use a two part epoxy 30 minutes or longer to fix it
Douggie
kinsei
09-12-2010, 03:17 AM
here the pics, the box arrived rather intact at all sides which makes me feel that this boat do suffer from some build quality problem
andym
09-12-2010, 04:32 AM
Come on D.Jordan send him a hull..................................This is were we all say BUY FROM OSE, sorry about that. Two ways to fix, easy way see if you can part it 1-2mm and use epoxy as stated above. If you use micro balloons it will even be white! Or use fiberglass resin and hardener the same way. Epoxy is easier and widely available just use a good one.
westbeach
09-12-2010, 10:11 AM
Epoxy or autobody filler works well, just make sure you sand the area of the chip a little more to get some good adheasion.
ron1950
09-12-2010, 02:28 PM
darin in another post says it is just painted fiberglass
Diegoboy
09-24-2010, 05:55 AM
Did you run it? or did you buy it used? I see rust in that second pic.
ron1950
09-24-2010, 06:26 AM
looks as if it spent alot of time on the ocean in shipping i hate rust
kinsei
09-24-2010, 10:16 PM
its new, shipped by EMS
i havent run nor fixed it yet. i have grabbed 2 brands of epoxy to try it out but i found its quite difficult to open some gap for filling without making it worse..!
for the rust, yes, but how come? its should be lot easier to fix than the crack with WD40 tho
side note: i didnt get any single reponse from horizon so far
AndyKunz
09-25-2010, 11:10 AM
Kinsei you have a PM. I forgot - please include your e-mail address in the PM when you respond. It will help me track down your contact to us.
Andy
kinsei
09-25-2010, 11:55 AM
hi Andy, replied, if you need more info pls just let me know! thanks a lot!
