View Full Version : BJ Flex cable size
FE_Chris
11-03-2007, 11:41 PM
What size is the flex cable on this thing? Im gonna order some hardware from a club member of mine to install and he needs to know!!!!! Thanks!!! :buttrock:
(PS - I Think it's .150)
RCprince
11-04-2007, 12:59 AM
I just put in a .150 kit from octura for $8.50...sweet
obrien
11-17-2007, 02:38 AM
I am assuming that with a new flex cable, the cable has to be cut to length. Is there anything special I need to know about doing that, or am I wrong?
I want to put a strut and rudder stet up on mine with a full cable so I can get rid of the universal setup.
10gauge
11-25-2007, 11:49 AM
I use a separating disk fitted to a dremel tool. Smooth the edges gently with fine sand paper. Melt solder circumferentially onto the terminal 1/2" where it enters the coupler. You may have to file off the extra solder to ensure a passive cable fit into the coupler.
If you're deviating from the stock Hardware, Get rid of the Turn fins. I recommend the Speedmaster 0.21 Round Bottom Strut and Hydro Rudder with 1.5" length. I have this set up in a Mean Machine and the boat runs bone dry.
FE_Chris
11-25-2007, 08:26 PM
I would'nt ditch the fins....I wish I would have left them on. The boat turns like crap without them. IMO from seeing other people vid's and seeing my own run. I say leave them on! This is not a mean machine....Although I wish it was...
obrien
11-27-2007, 06:32 PM
Chris are you still running the stock drive or have you upgraded?
FE_Chris
11-28-2007, 07:43 AM
I have partially installed the Mach5 6-12 cell cat hardware (It' OK)...But i have not ran it....I still have to fill some holes and ajust some things.
I'll take some pics sooner or later....with the cold weather I have not been much into the boat latley....or RC for that matter...
obrien
11-28-2007, 09:21 AM
where can I get some more info on the Mach 5 hardware? What is the cost on it?
