View Full Version : Vid Of P1
hobie
09-01-2010, 11:08 PM
Here is the new vid i took today with the new P1. its running about 42 MPH
hobie
09-01-2010, 11:59 PM
Whoops!
Sorry, new to this forum stuff. I posted it on you tube. Here is the link.
I will figure this out sooner or later.
http://www.youtube.com/watch?v=_NK2-J8m-pg
matthj72
09-02-2010, 11:24 AM
What kind of set up are you running to get those speeds?
hobie
09-02-2010, 11:50 AM
I am all stock except the prop. It's a octura X640. 1 degree of pitch up. My battery is a 4200 mAh 4S, 45C Hyperion. Oh, and I threw a Tactic 2.4 reciever. But I'm pretty sure that's not helping it go any faster! Lol.
Speed control temped out at 86. Motor was 119 degrees. Battery was about 85 as well. Runs great.
Awesome boat.
matthj72
09-02-2010, 12:36 PM
Nice! That is the prop that I was planning on trying next. Where did you get the shim for the prop to fit onto the prop shaft?
hobie
09-02-2010, 12:51 PM
I bought a piece of 3/16 tubing. Inside diameter is .14 or .014. Can't remember that number. It's the usual stuff at the LHS.
I also have seen them in the store on this site.
There is also an adapter that's supposed to fit the cog of the 3/16 props, and thread right on to the 4mm shaft. It's on it's way.
Diesel6401
09-02-2010, 01:54 PM
http://www.offshoreelectrics.com/proddetail.php?prod=ose-1030
forescott
09-06-2010, 03:06 AM
Here is a short vid of mine on 3s, x442. Steering rate is turned down, but still spins out real easy. Needs a couple of turn fins!
rH_o20IgWVM
Diesel6401
09-06-2010, 10:24 AM
I love the sound of outrunners. Has potential that's for sure, some nice turn fins would def help.
forescott
09-06-2010, 11:23 AM
It sounds like the stock sv motor to me. Temps were really hot after about 6min. on 3s. Right around 160 degrees with the 442. I'm gonna prop it as small as I can on 4s and hope it runs cooler. Kinda weird, seems to run hotter on 3s than 4??
Diesel6401
09-06-2010, 11:39 AM
I think it sounds a little better than a SV. Yea that's pretty hot, maybe cut the runtime to 4ms may help. I am sure propping smaller will help.
jamespl
09-07-2010, 02:14 PM
That looks awesome, can't wait to get mine. Going to try running it on 2x 2s and I've ordered an octura x640 prop. Anyone got a water jacket for the outrunners yet, if so what size fits? Deffo needs turn fins I think.
Skullcracken
09-10-2010, 11:30 PM
Does the P1 run off of one battery or two? Is your's an outrunner motor or inrunner. I remember old pics of it with the green inrunner.
hobie
09-11-2010, 01:06 AM
This has the new outrunner motor. I'm running both, 1 and 2 pack configurations. I have 2 5000mAh 7.4 volt packs at 20C. I also just picked up a 4 cell 14.8 volt 4200 mAh 45C pack. That's where I got the 42. But now after 5 or 6 charges, I'm down to about 39.7 mph. Must have been just the new pack?? Either way it costs about the same. The single pack at 45C is a nicer battery.
Diesel6401
09-11-2010, 02:11 AM
It's easy to loose or gain 3mph depending on water current. You may have had a nice current when you hit 39.7 a didn't realize it. I've hit 47mph in my SV before, but it averaged 44mph with ul-1 power. It's in the low 50s now with a 7xl, also if your lipos are a little warm prior to your run you can gain some extra mph's that way as well, that's why some racers pre-heat the packs...
Brushless55
09-12-2010, 02:54 AM
they look like they handle well :thumbup1:
Skullcracken
09-15-2010, 09:23 PM
Someone asked you about being able to fit the prop you changed to. What tubing is needed. I'm a newb, I want to get that boat but I am clueless with what props are right for boat. What type and size of tubing to I ask for?
hobie
09-15-2010, 09:33 PM
If you use a 3/16 prop, then the 3/16 brass tubing will work as the adapter. I do believe it .14 or .15 in thickness.
I also used a small price of aluminum as a shim for the rudder strut. It raised it up about a 1/8-1/4 of an inch. I can now use the octura x640, and angle the stut all the way up without hitting. Before my adapter piece, I could only have it a 0 degrees.
I really really like this boat. The setup is sweet.
Hope this helps.
I have a thread titled rudder placement question with a pic there. I extended as well as lifting it, the extension was BAD!! Lost 9 mph with it extended. Just need to lift it.
Diesel6401
09-15-2010, 11:39 PM
READ ME (http://www.offshoreelectrics.com/info-pages/fit-propellers.php), stock is 4mm so you need to go to 3/16. Read the first part.
