View Full Version : Small Couplers
SweetAccord
08-30-2010, 01:32 AM
Greetings,
I'm looking for a motor coupler/collet for a 20x40mm motor. I don't want anything that would use a set screw on the wire drive. A grub screw on the motor shaft side is fine but not preferred. Here is what I'm looking for.
Specs: Motor shaft is 2 mm (screw or compression type is fine) and on the flex drive cable side must be compression type collet that is .098 or .094. Does anyone know where one may be purchased or who may make this?
Thank you in advance. :smile:
SweetAccord
08-31-2010, 07:06 PM
I found my soultion.
Thanks all.
ray schrauwen
08-31-2010, 08:53 PM
What is the solution?
SweetAccord
09-07-2010, 08:48 PM
Seems that ETTI is the only one that carries these small couplers so will order from them.
Peace.
