View Full Version : hk turnigy 180 amp esc?S
Trevor January
08-30-2010, 12:47 AM
hey guys
have you ran this one 6s and if so are you having any problems
i was running this in my hk apparition with stock motor and hk turnigy 180 amp with grimracer 40-53 prop and on 4s 2p 5000mah it's awesome runs hard 12 to 13 min run times all day no problems at all, now put 6s 2p 5000mah and it starts out hard and then dies of almost like it's in low volt cut off but the batts are fully charged and the volt cut off is on auto
i don't get this i think it might be amping out as in drawing more then i can threw the 180 amp or my battery dose not have the c rating to do the run
any help would be awesome
Trevor
Flying Scotsman
08-30-2010, 01:04 AM
Remove the LV cut off and did you program the ESC for 6S...not familliar with the hull....12 minutes???
Douggie
Trevor January
08-30-2010, 01:18 AM
so i looked again and it has only
Programmable settings;
Reverse
Low Voltage (none/2.8v/3v/3.2v/3.4v)
Brake: (none/soft/hard)
Timing (0.00/3.75/7.50/11.25/15.00/18.75/22.50/26.25)
Constant Current: 180A
Burst Current: 360A
Resistance: .0007ohm
Battery: 2-6S Lipoly
BEC: 5.8v/ 3A
Motor Type: Sensorless Brushless
Size: 72 x 68 x 34mm
Weight: 165g
i guess i was wrong for auto lv cutoff
the for 6s i should be at 3.4 for lv cutoff and why dose it work on 4s 3s 2s with out changing anything but 6s dies out
and the hull is the apparition 800mm twin hull cat with a single drive and yes about 12 mins of ripping fun but it's not always wot so that might explain the 12 min run times
Flying Scotsman
08-30-2010, 01:30 AM
There have been some issues with this ESC on LVC ...program none....but be very cautiuos on your run times or use another LVC device.
Douggie
Trevor January
08-30-2010, 01:37 AM
cool
but i find it hard to believe it would run hard on 4s and on 6s rips but only for about 4 seconds in the water the it dies out odd never had anything like that , do you know what programing cards can be used on these ?
Flying Scotsman
08-30-2010, 03:39 AM
Are you using the bec circuitry?
I always use a stand alone power source...old school, but it works for me.
Douggie
SweetZ28
08-30-2010, 08:46 AM
Anyone know if this problem happens to there 60 amp esc also because i have one headed my way?
THANKS
forescott
08-30-2010, 09:33 AM
I have the same 180, but my settings are....
1-forward only/reverse
2-#of cells
3-low voltage cutoff
4-timing
There is no brake option on the turnigy/seaking 180. Better check those settings again.
Trevor January
08-30-2010, 10:54 AM
i got it right of hk and i sure your 60 amp will be fine and now that you said that doug i think it is the bec because i had a problem like that with my car one time to much power would cause the bec to clip for signal and i would lose power to the motor
ill try that
Rumdog
08-30-2010, 01:35 PM
OK, the big question here, is are you running the stock motor on 6s?!
785boats
08-30-2010, 03:10 PM
We've had this problem on a 180A & 120A at our club.
The solution was to switch off the LVC cutouts. There's something wrong with the internal software in some of the ESCs. Use an external LVC if you need to.
Cheers.
Paul.
Trevor January
08-30-2010, 08:50 PM
cool thats what i wanted to here and thanks and yes i will be running it on 6s
Rumdog
08-30-2010, 08:53 PM
what is the kv?
Trevor January
08-31-2010, 11:02 AM
1600 but i changed it out to the 540l 2336 from ose and now it's ripping but i have only tried it on 4s and as of now it's pushing 39000 rpm
Trevor January
08-31-2010, 11:03 AM
dose any one have any problems with programing cause mine is really being a pain but then again i am only using the radio cause i don't have a program card
Rumdog
08-31-2010, 12:12 PM
Bad idea. That motor is too small for your hull. Also, that is a hot motor for 4s. I will not work with 6s, and you may destroy more than just your motor. Get yourself a 9xl and run on 4s. It will be reliable and fast.
