today i was running my sv27r and it was running great suddenly it stopped n the water. the cable didnt come lose, but the flext shaft just snapped clean off the actual fixed shaft. whyyyyy
flex cable broke
Tags: None
Why?
- cable rusted through because the owner failed to dry it out each day and re-lube
- poor alignment with the motor coupler
- teflon liner wore out or got tangled with cable
- not enough gap between drive dog and strut
- too much stress due to large prop or hotter motor
- faulty cable
- they are considered an expendable item and do wear out
They come pretty well grease from the factory. So it shouldn't have broke on the second run. Fluids given some good reasons, it also could have not been soldered into the prop shaft straight and self destructed.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
