View Full Version : Voltage requirements for Castle 120 HV
danielplace1962
08-24-2010, 11:16 PM
Have Castle 120 HV,
The programming chart says default cutoff is set for 12 volts and the minimum available setting is 9 volt.
Was planning to use 2S.
ESC boots and operates perfect on 4S which it should with factory default of 12volt LiPo shut down.
Don't know what good setting it to 9 volt would do as a 2s fully charged only goes to 8.4 volt.
Is this just not made to work on 2S?
Doug Smock
08-24-2010, 11:24 PM
Have Castle 120 HV,
Hi Daniel,
That control will operate on 2s. Do you have these instructions?
http://www.castlecreations.com/support/documents/hydra_user_guide.pdf
Doug
danielplace1962
08-25-2010, 12:24 AM
Hi Daniel,
Doug
I have instructions for my HV model. These models also requires external receiver power source.
http://www.castlecreations.com/support/documents/hydra_hv_user_guide.pdf
Doug Smock
08-25-2010, 06:59 AM
Man I'm sorry I didn't see HV in your post even though it was there twice.:o:doh:
You are right, you're going to need a LV control or change the setup. What are you working on?
Doug
danielplace1962
08-25-2010, 09:08 AM
Doug
Doug,
Thanks not a problem. It is a twin motor Mini Mystic, the motors are 7.4 volt 7 wind Lehner. Was going to do 2S2P 5500mah lipo.
http://www.youtube.com/watch?v=Uo6X-SrbUEE
Build thread,
http://forums.offshoreelectrics.com/showthread.php?t=17232
6S HYDRO
08-25-2010, 02:34 PM
Yeah hv stands for high voltage, 7.4 volts is not high voltage- like 6s and above
