View Full Version : Prop spinning wrong way
Brushless01
08-23-2010, 10:35 AM
Hi I have just finished building a delta force 29 Knock off with supervee 27 motor and esc with speedmaster hardware. I powered it up for the first time and the prop span to the left. Whats wrong here ??
Thanks
video200
08-23-2010, 10:42 AM
swap 2 of the motor wires to make it go the other way around
Brushless01
08-23-2010, 10:50 AM
I tried that which colours should i swap ??
video200
08-23-2010, 10:51 AM
dont matter. just swap 2 of them and you should be good to go
Brushless01
08-23-2010, 10:55 AM
Tried that blue to red didnt work now trying blue to yellow
Brushless01
08-23-2010, 10:56 AM
:help:Tryed switching all the wires didnt make any difference what so ever
video200
08-23-2010, 10:57 AM
you did 2 at the time right ?
2 of 3 wires
Brushless01
08-23-2010, 10:58 AM
Whitch way should the prop actually turn
Brushless01
08-23-2010, 11:00 AM
2 of 3 wires
yes you cant only change 1 can you
video200
08-23-2010, 11:02 AM
lol no thats true.
my mind is not always with me im afraid :)
Brushless01
08-23-2010, 11:08 AM
Which way should it actually turn
video200
08-23-2010, 11:11 AM
a brushless motor SHOULD switch the way it turns with swapping the wires.
there is not a set way it should turn. they can turn both ways just as good
ED66677
counter clockwise when looking at the prop from the back... but depends if you spin a L or R prop!
Brushless01
08-23-2010, 11:12 AM
The props meant to spin to left yes
ED66677
08-23-2010, 11:20 AM
then swapping 2 wires should change motor direction
westbeach
08-23-2010, 07:16 PM
You should always check the motor turn direction before you hook up the flexshaft or it could unwind on you. The prop should blow air on you if it is turning in the right direction.
Thanks
