View Full Version : Ampba " ea outboard " question
rcboatmanwithkids2880
08-19-2010, 06:57 AM
Hi Guy's :bowdown: ,
Currently i am building a 32 inch tunnel hulled boat , that has an Outboard powered leg , i have 2x 2s 40c batts & 120 amp ESC . just trying to ascertain what motor is used in the " EA- Outboard Class " , i have my eye on an Ammo 36-50-2300 or UL1 36-56-2030 ...
Any advice appreciated :bowdown: ,
Brad
Scott T
08-19-2010, 05:12 PM
Brad, EA allows any motor. However, you might want to check with your local club to see if they have any restrictions. What's the hull?
Kris Flynn
08-19-2010, 05:39 PM
Hey Brad,
Most are going with the UL1 Motor, plenty good enough!
Kris
08-19-2010, 09:37 PM
Hi Guy's ,
The hull is a Vantex that i have changed to outboard configuration , gave the guts of the original set up to my brother so he could put it into a project boat he sharing with his son . So i may buy the Ammo as it seems on specs it's a touch more powerful than the ul1 unit ( 60 amps ammo - 50 amps ul1 ?? ) , plus ammo has higher kv rating or would you still suggest the ul1 . The props i have are Octura x642 n x640
Thanks Muchly ,
Brad
08-19-2010, 09:51 PM
Hi Guy's ,
Attached a couple of pics of what state the project is at , just waiting for warmer months to finish painting ....
