View Full Version : Turnigy 180
Barrie Clarke
08-15-2010, 09:09 PM
Has anyone used a Turnigy 180 with 6S pack? .... was it successful? or any comments.
I have used it with my 4S with no problems so far, but would like to try it on my 6S rigger.
I have been running a HV hydra 180 (Castle), but it got wet on the weekend:crying:
and it looks like a repair job.
08-15-2010, 10:09 PM
It is my practice - and that of a lot of other experienced boaters - not to run an ESC at its maximum voltage rating. Some get away with it fine, but IMO it greatly increases the chances of an ESC meltdown. As long as you keep the amperage down you will probably be fine, but try for that extra 10 mph and you definitely are at a higher risk.
Make-a-Wake
08-15-2010, 11:05 PM
I run two................one with a Feigao 580L 1051kv on 6s, and one with a Neu 1527 1250kv on 6s...............no problems at all here.............
Alexgar
08-15-2010, 11:12 PM
t180 on1515 on 6s no probs an swordfish 120 on a 1415 6s no problem
kevink
08-15-2010, 11:16 PM
Ran my Turnigy 180 on 6s with stock Proboat 1500 kv motor and blew the esc in two runs. Supposed to be able to handle, but do so at your own risk. I have two others on 4s with Neu 2200 kv and Feigao 8xl and no problems. Good luck.
Flying Scotsman
08-15-2010, 11:17 PM
I believe the statement Fluid made is correct, but if you wish to push the envelope go for it.....a lot will depend on your setup for success or ??? and a trip to the LHS may be in order after that experience
Douggie
