sanyijr
08-10-2010, 06:20 PM
So I am running 7.4V lipos, X642 prop, low timing, stab fins 90-degrees to hull. Drive is about as low as it can go with slight negative angle down. All else is stock (except 2.4G radio which is awesome)
Runs great but at WOT, it will drift or wabble slightly from side to side. It runs in a straight line, but rolls side to side might be a better description. Is this normal? I don't recall this happening with the stock plastic prop, but I chipped the plastic prop a few hours into getting the boat into the water. Metal prop is wway better overall. Faster, smoother, quieter and oh yes, faster.....
Any suggestions? It turns like on rails! But cavitates a hair as well when plaining out of I am a little slow on the throttle. Thanks.
