View Full Version : Seaking 60A ESC timing setting
kookie_guy
08-10-2010, 02:02 PM
So from the factory, the setting is at 15 degrees timing.
The motor in the shockwave is a 36-50-04 (4 turn, 3300kv).
Should I be running the timing that high? From what I have read on here and other online sources, higher timing means higher speed, but also higher temps. Should I program it to start at 0 timing, and monitor and go up from there? Or is it safe to start higher/leave it at 15?
Alexgar
08-10-2010, 02:08 PM
let me dig up my manual
blackcat26
08-10-2010, 05:23 PM
I would say 15 should be fine. Probably gonna be your best balance between speed vs. heat.
