View Full Version : Charging multiple lipos in series using Accucel 6 charger?
ms71171
08-07-2010, 07:28 PM
I bought one of these to charge 2 3s lipos at once, but the connector for the balancing board does not fit mu Accucel 6 charger. http://www.helidirect.com/bantam-multibalancing-board-for-thunder-poweroutrage-bc6bc610pb6-p-7595.hdx
Anyone charged multiple lipos using an Accucell 6? If so, could you post a link for the balancing board that is correct?
The Accucel has a 7 pin and the balancing board had 8 pin.
osprey21
08-08-2010, 11:09 AM
What brand batteries are you trying to charge?
ms71171
08-08-2010, 02:21 PM
I'll be charging:
2 - 2S 20C 5000mah Turnigy
2 - 3S 40C 5000mah Turnigy
2 - 3S 25C 2200 mah Turnigy
I just ordered a Turnigy Accucell 8150 charger and I've read on here that the connector will work on this charger and it is an all around better charger at 150w.
LiPo Power
08-08-2010, 02:24 PM
check this out:
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=11170
LarrysDrifter
08-08-2010, 03:04 PM
Thats sweet.I gotta have one of those!
LiPo Power
08-08-2010, 03:15 PM
I Love it!!!
http://forums.offshoreelectrics.com/showthread.php?t=14737
wizard122
08-08-2010, 07:08 PM
Remove outside black wire and trim connector works great
http://forums.offshoreelectrics.com/showpost.php?p=201671&postcount=14
ms71171
08-08-2010, 11:01 PM
Thank you for the replies. I went ahead and upgraded to the Turnigy 8150. I think it has the 8 pin. If not, I'll remove the black wire.
wizard122
08-09-2010, 12:15 AM
The wire I said to cut is not hooked up to anything its there for no reason except so it will only fit a Bantam charger ohm it out if you want to. Please look at my whole thread I use the same one with my 8150 and my BC6
