View Full Version : Trim tab question....
stringfly
08-01-2010, 11:48 AM
Just got a 27R and was wondering about the 2 rear trim tabs. The bottoms are NOT flush with the bottom of the hull. They are factory attached about 3/32" up from the bottom. Is this correct ??? I can easily elongate the screw holes and drop them down so they are flush. Should I do this ??? Thanks for any help on this.
Stringfly <>+++++
osprey21
08-01-2010, 01:05 PM
This pic from Aquacraft's website show them as you describe. I changed-out mine for the adjustable tabs and they now sit flush to the bottom.
08-01-2010, 07:06 PM
Most racers install the tabs slightly above the hull bottom. This gives less drag, especially if you don't need them adjusted down much. I always install mine with the bottom edge 1/16" above the transom bottom. Less drag = more speed.
stringfly
08-01-2010, 08:41 PM
Thanks guys... will leave them as is until I run.
Stringfly <>+++++
Brushless01
08-02-2010, 03:12 AM
Are you using the stock prop ?? For the first run tuck under the rudder to make the boat much more stable and easier to drive.
stringfly
08-02-2010, 12:00 PM
Yes...stock prop at first but have a Grim 3 and 2 blade for it. Thanks, will do that for first run.
Stringfly <>+++
