View Full Version : New outboard
F1 madness
07-26-2010, 01:27 PM
Well here you have it,been working on it for some time with a friend of mine who does C.A.D.
Weve designed it to be able to run 540+ motors,with 12* angle adjustment,12mm height adjust,will be used with 3/16 flexi & stub shaft so a variety of props can be used,and be able to run upto 60mm props.
As you will notice the motor mount is at an angle,this is to releive some of the friction on the flexi and the teflon liner.
Im planning on having these done in cast alloy.we are just about to have the first 1 done in carbon poly plastic.theirs just 1 adjust to make before getting the 1st 1,and that to make the steering ears a little wider for more leverage and less stress on the servo.
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/Myoutboard4.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/Myoutboard3.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/Myoutboard.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/Myoutboard2.jpg
What you reckon
Rumdog
07-26-2010, 01:36 PM
Very nice!
bigpapa
sweet thats nice
F1 madness
07-26-2010, 01:38 PM
cheers guys,im planning on testing 2 of these on my twin outboard cat,with scorpion out runners,cant wait to get the 1st prototype back.
gerardobrandao
07-26-2010, 01:41 PM
..From the drawing smells me Autodesk Inventor or Solidworks ...... :biggrin:
Good to see the great work....i expect future releases......
If you have access to rapid prototyping machinery yould make the mold in the blink of an eye......
congratulaitons for the work..expect to see it ......real..
:thumbup1:
F1 madness
07-26-2010, 02:12 PM
:thumbup1:
Pass my mate does the cad,i can just about send messages and post pics LOL
If i get enough interest then may decide to produce them forsale.
Again my mate sorting out the the 1st model and moulds as hes in the know.
I just designed on paper and gave him all the dimentions needed,i spent weeks reseaching and trying to design somthing to cope with bigger brushless & bigger props.
Im testing the first 2 using HK40 series scorpion outrunners so should be interesting to see how they handle it
6S HYDRO
07-26-2010, 02:23 PM
is it gonna be machined alum. or molded plastc- or cast alum?
F1 madness
07-26-2010, 02:26 PM
the first 1 is carbon poly,then will be molded for cast alloy
DPeterson
07-26-2010, 08:54 PM
I like it. Very cool.
I am planning to do a 4S 34" tunnel in the near future with a true open power motor.
Was going to start to hunt down a 7.5 size Lawless. This looks like a better choice.
When you are ready to produce some please let me know.
Doug
Doug Smock
07-26-2010, 08:58 PM
Very nice sir!!
Doug :beerchug:
07-26-2010, 10:43 PM
Unless you are going to redesign the bushing and prop shaft for the better, I suggest using a current stubs and bushings availible. Like the HyperPerformace one. Its one less part to make.
By the way its quite nice looking.
F1 madness
07-27-2010, 05:59 AM
Cheers guys.
Alrite steve was going to pm later.
Also weve been looking at ceramic,sealed bearings and a longer stub shaft to mount the larger hubs on the bigger props.
Also there will be 2 water pick ups 1 for motor and 1 for ESC,but this will be an order choice depending on what your going to be running.
bigpapa
07-27-2010, 08:28 AM
love the green fe-1 boat
Gerwin Brommer
07-27-2010, 09:01 AM
Sharpen the bottom of the vin to avoid lift ?
sailr
07-27-2010, 09:25 AM
It would seem to me that with some of the thin elements of the unit that casting may produce some very weak points?
You may have a winner on your hands if it works out and you can sell it for a reasonable price! Regardless of its future, it sure is pretty!
QUOTE=F1 madness;210870]the first 1 is carbon poly,then will be molded for cast alloy[/QUOTE]
F1 madness
07-27-2010, 11:36 AM
cheers bud thats the 2nd boat i ever built,not bad considering LOL
it is sharp,its just when converted to jpeg file is is not as prominent,but will sharpen it up when they come out of the cast moulding and polish it
[QUOTE=sailr;211229]It would seem to me that with some of the thin elements of the unit that casting may produce some very weak points?
Cheers bud,hes coming round tonite to make a couple of changes,1 of them is to widen the steering ears for less load on the servo,also the thickness of the motor is a little too thin and add some fillets where it joins to the lower part of the leg.
Like said this is just the 1st preveiw of it,and wanted to see what people thought and point out anything that could be altered
F1 madness
07-27-2010, 04:51 PM
Made some alterations,to what i felt need to be changed and this is the final design,should hopefully have the 1st 1 here the towards the week end.
this baby will take upto a 50mm diameter motor with hole spacing upto 25mm,so a large variety of motors can be used.
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/FINALDESIGN.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/FINALDESIGN1.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/FINALDESIGN2.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/FINALDESIGN3.jpg
Please leave your comments positive or negative
Thanks daz
bigpapa
07-27-2010, 04:54 PM
good luck
bigpapa
07-27-2010, 04:56 PM
man thats gonna be a jewl good luck with the test and awsome wk
F1 madness
07-27-2010, 05:04 PM
Cheers bud,im excited now,cant wait to see it the end result of the first model,then gotta get moulds made for cast alloy:rockon2:
bigpapa
07-27-2010, 05:07 PM
i would be also, think its gonna a big big hit when finished, cannot wait to see product after production, keep intouch and keep up the great wk :)
F1 madness
07-27-2010, 05:10 PM
thanks bigpapa,i hope so will be worth all the effort if it is a big hit LOL
i will stay in touch bud
rchippie
07-27-2010, 06:00 PM
I understand the reason for the angle, but will that cause a issue with the motor hitting the canopy on some of the boats ?. But it looks very cool :smile:.
F1 madness
07-27-2010, 06:10 PM
It probably will on some hulls,but i could always supply a spacer if needed, or if competant builder could always modify the hull to suit.
rchippie
07-27-2010, 06:38 PM
Thats very true. It looks really good in the cad pics :smile:.
F1 madness
07-28-2010, 03:02 AM
Cheers bud:bounce:
F1 madness
07-28-2010, 02:23 PM
Well the first 1 in ABS Plastic is being printed a we speak & will be here before the weekend hopefully.
This will be what we will use to make the moulds for cast alloy,but will give us more of an idea if we need to change anything,but honestly i dont think there will be (fingers crossed)
bit different in the flesh rather than on the screen
will probably mount it to the back of my 34"F1 hull iv built for some pics and test fit.
bigpapa
07-28-2010, 02:51 PM
well daz it seems a weekend of testing is comong , cannot wait to see pics ........
good luck todd
F1 madness
07-28-2010, 04:13 PM
will be test fitting thats for sure and see hows its gonig to mount etc.
got order stubshaft and flexi soon,but costing me a fair bit just to get this sorted first
will keep every1 posted
F1 madness
07-29-2010, 06:38 AM
Heres some more pics my mate was fooling around and thought it would be good idea to place a motor on just so it gives you more of an idea.
He used the dimentions off a scorpion 4035 outrunner.
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/outboardwithmotor4.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/outboardwithmotor3.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/outboardwithmotor2.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/outboardwithmotor1.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/outboardwithmotor.jpg
bigpapa
07-29-2010, 07:13 AM
man thats nice ..........great job
properchopper
07-29-2010, 09:12 AM
:popcorn2: Watching and waiting. Good thinking on the reduced shaft angle. I use the Hyperformance angle drive just for that reason & have had great luck with shaft longevity. :biggrin:
F1 madness
07-29-2010, 10:06 AM
Thank you,iv got an old dolphin outboard and that runs a quite a tight 90*angle and was playing round with that and the difference between turning it with your fingers as is and then reducing the angle was alot smoother and easier to turn,so by doing this is less strain on the motor and the flexi and less wear
I think so,im really really pleased with the way its turned out so far,just gotta get it in cast now and performing and being reliable.
bigpapa
07-29-2010, 10:08 AM
daz i see you made it through the night lol
F1 madness
07-29-2010, 10:17 AM
i did LOL,got it sanded and another coat of sealer,so will sand that and start filling ready for primer
bigpapa
07-29-2010, 10:20 AM
awsome cannot wait to see her painted
F1 madness
07-29-2010, 10:52 AM
wont be long bud and will start shooting the primer over it,im sanding as we speak/type LOL
bigpapa
07-29-2010, 10:53 AM
keep us posted
F1 madness
07-29-2010, 11:40 AM
Just recieved a phone call the parts are done and will be here later today,so will post some pics as soon as there here :banana:
beau0090_99
07-29-2010, 01:50 PM
Wow, you Brits move quickly. I love it. My only concern would be the distance from the steering pivot point to the prop. Is this significantly longer than most outboard conversions? This will add torque to the steering servo and may make the boat a bit unstable. If you could move the pivot further back to the prop, it may reduce this significantly. I'm not sure if I am clear, but I am optimistic for you and wish you the best of luck.
Curtis
6S HYDRO
07-29-2010, 03:06 PM
dont want to hijack your thread but i am also working on a new type of outboard
its an L.C.G. mount meaning low center of gravity and also will have a small bend angle. I designed it, drew the 3d drawings, and will be cnc machining them myself under the name ElectroMarine products. heres some prototype renderings
http://i721.photobucket.com/albums/ww218/6s-hydro/LCGOUTBOARD6.jpg
http://i721.photobucket.com/albums/ww218/6s-hydro/LCGOUTBOARD3.jpg
http://i721.photobucket.com/albums/ww218/6s-hydro/LCGOUTBOARD2.jpg
http://i721.photobucket.com/albums/ww218/6s-hydro/LCGOUTBOARD4.jpg
http://i721.photobucket.com/albums/ww218/6s-hydro/LCGOUTBOARD5.jpg
F1 madness
07-29-2010, 04:21 PM
cool cant wait to see the finished product
6S HYDRO
07-29-2010, 04:27 PM
i cant wait to see yours too. mine will not be completed for a while as i will be doing all the programming and cnc myself for it. i still need to design the steering horns for it as well
6S HYDRO
07-29-2010, 04:29 PM
they will all be cnc machined alum. so a bit more pricey.
F1 madness
07-29-2010, 04:31 PM
Iv just got back my first prototype model,not gonna run this 1 but use it to make the moulds from,but also gives us a chance to see it before hand.
HYang fire,im just uploading the pics.
F1 madness
07-29-2010, 04:42 PM
well here it is the first model of my outboard,iv mounted it to the back of my 34" F1.
just gotta sort out the stub shaft & flexi now.
Im not using this 1 to test,gonna make moulds of it and test the cast version and go from there.
The motor sitting on top is a 540L again for test fitting.
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/DSC00190.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/DSC00191.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/DSC00189.jpg
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/DSC00188.jpg
6S HYDRO
07-29-2010, 04:46 PM
sweet, is that made from a 3d printer
bigpapa
07-29-2010, 04:48 PM
daz that looks awsome good luck on the molds
F1 madness
07-29-2010, 04:49 PM
thanks bud
think so ,my buddy who did the cad work for me sorted it
F1 madness
07-29-2010, 04:50 PM
Cheers bud,hopefully,next week ill have the moulds,gotta take it to the casters now to sort them.
6S HYDRO
07-29-2010, 04:55 PM
i believe thats the only way to get the flex hole in there on a solid piece. i believe your gonna have to cut that in half to make the molds for that, otherwise its imposible to drill a arced hole for the flexdrive
F1 madness
07-29-2010, 05:00 PM
The casters will sort that bit and use a core in the mould,they ll sort it thats what im paying them for LOL
F1 madness
07-29-2010, 05:55 PM
had a brain wave,depending on cost what about instead of being just plain alloy once casted,what you reckon to anodising the OB in colours,red,purlpe,blue,black,green etc,got to make a few enquires but think it would be awesome to offer somthing completely different.
What you guys think
Rumdog
07-29-2010, 06:10 PM
I dig the white!
CornelP
07-30-2010, 12:41 AM
Look for anodizing on the net... it is quite easy to do if you're careful. It does involve some nasty chemicals, but it is very straightforward.
F1 madness
07-30-2010, 03:48 AM
will do bud,i think there is a company down the road from me that does it,will definately look into it,think i would be quite cool
F1 madness
08-04-2010, 07:44 AM
Going to see about getting the outboard moulded and casted now (also possibly anodising) will keep you posted
bigpapa
08-04-2010, 08:31 AM
you do that and best of luck daz
TotalPackage
08-04-2010, 10:02 AM
Nice work man .What do you draw in?
