Simon.O.
07-24-2010, 04:40 AM
I hope I can descibe this one as I see it.
My bigger twin cat has a pair of outrunners 1600kv and 1500W capable, as of now I am sure that I do not use all of that avaiable power because after a 2 min wot run they are warm but not hot.
They are fed with 100 mystery type aircooled esc's that get warm but not hot so I am guessing I am in the 80A range.
I currently use 5S made up from 3S+2S 4500mAh 30C to give me 135A available.
IF I am up to about 80A with the power system (each side) then I think it is best to upgrade my packs even though they are warm but not hot or swelled after a good blast on the pond.
Here is where the question kicks in.
I can go with a single 5S pack that can provide 200A or go with two smaller packs at 100A each to give me a combined 200A feed.
I have chosen 200A total as I am happy to feed 100A to each esc. btw these are about to be swapped out for a pair of 150A units as the boats they were robbed from are begging to get wet again.
Now if I choose to go with a total of 200A and say 4500 mAh+ can I make this up from any type of combination, example.
5S 5000 mAh 40C single
5S 2500 mAh 40C 2P
I am concerned that the smaller packs, even though the numbers stack up, do not have the physical size to do the job.
What I need is 5S feed to two motors. 100A per side will be enough for this hull.
I want to run 6 to 8 passes (100m or 330' per pass) about 2 mins is plenty.
Now how to I configure my packs. ? Weight will become an issue above 800g or 28oz.
I said at the start that this may not be too clear.
5S 2500 mAh 40C 2P
