View Full Version : widomaker and lipos
bigpapa
07-22-2010, 09:29 AM
this is direct from proboat about the widowmaker battery's
HI Todd,
Thank you for contacting Horizon Hobby Product Support.
The widow maker was not designed for Lipo batteries. There caption was
taken directly out of the manual:
Due to the high current demands of
a brushless powered boat, Pro Boat
recommends only the batteries listed
above or equivalent.
If you should need further assistance regarding this issue please reply
to this e-mail for additional support. If you need assistance in the
future, please feel free to e-mail us at productsupport@horizonhobby.com
or you may also contact us toll-free at 1-877-504-0233. Make sure to
visit our web site at http://www.horizonhobby.com to see all of our
newest products!
Thank You,
David W.
Horizon Hobby
Product Support Team
4105 Fieldstone Rd
Champaign IL 61822
1-877-504-0233
:Shame_on_You::Shame_on_You::Shame_on_You:
bigpapa
07-22-2010, 09:31 AM
found this instering............
Diesel6401
07-22-2010, 09:58 AM
WidowMaker 22 Deep-V BL RTR
Key Features
Brushless power makes it faster than conventional electric boats
Fiberglass construction for great appearance and durability
Installed Pro Boat® 2-channel AM pistol-grip radio offers solid control
Optimum cornering and adjustability thanks to aluminum offset rudder
Ni-MH/Li-Po Switch allows easy change from Ni-MH to Li-Po batteries
Water-cooled motor and electronic speed control with reverse
Battery and electronics accessed through magnetic hatch that securely mounts to the hull
Receiver and servos protected by quick-access water-resistant radio compartment
Overview
Hit the waves with the Pro Boat® WidowMaker 22™ Deep-V brushless-powered speedboat. Along with its durable and attractive fiberglass hull, this boat only requires a single battery, providing exceptional durability and performance at a price that won't break the bank. The included ESC comes Li-Po-ready and contains a built-in voltage cutoff that allows you to safely increase the performance of the WidowMaker by simply dropping in your favorite 2S Li-Po pack. The WidowMaker isn't lacking in looks, either. A military-inspired trim scheme and a hull engineered with a 'stealth' design ensure that the WidowMaker will stand out on the lake or on display.
Needed to Complete
Battery
Charger
Marine Grease
8 AA Batteries
If their saying it was never designed for lipo's that isn't what their promoting.
bigpapa
07-22-2010, 10:28 AM
this is direct from proboat i asked then if the boat could run 3s lipo's and that is the response i got
forescott
07-22-2010, 09:22 PM
Do they actually recommend any particular batteries in the manual??
Diesel6401
07-22-2010, 09:52 PM
http://www.horizonhobby.com/Products/Default.aspx?ProdID=DYN5360D
Manual
http://www.horizonhobby.com/ProdInfo/Files/PRB3900-Manual.pdf (page 3 is batts)
bigpapa
07-22-2010, 11:55 PM
Well i just stuffed a smc 7.4v 6000 mah 28c in mine
guess we will see lol
mp3ranger
07-23-2010, 06:55 PM
This is right form the manual
You will need to purchase the following to get your boat on the water:
• 8 AA alkaline batteries for the radio transmitter
• 1-7.2V Ni-MH Battery Pack with Deans Connector (PRB3313 or PRB3314) or 1-7.4V Li-Po 25C
Battery (DYN5360D)
Scott T
07-23-2010, 07:06 PM
I think they mean it's not designed for 3S lipo - which is the question you put to them. 2S seems to be OK by the manual.
Diesel6401
07-23-2010, 07:07 PM
I remember reading somewhere that boat keep blowing the esc because a issue with the lipo/nimh switch on the older versions. If you have the old verison you may want to swap that esc out with something else. Just a thought.
bigpapa
07-24-2010, 08:15 AM
correct they are replacing esc under warranty, switch is up graded and problem supposed to be solved
mp3ranger
07-24-2010, 09:05 AM
So how do you know if you got the old esc?
bigpapa
07-24-2010, 09:14 AM
probally have to call proboat tech support, or see if it smokes ?????????
Diesel6401
07-24-2010, 10:22 AM
Plug it in and see if it goes :flashfire: lol
mp3ranger
07-24-2010, 08:54 PM
Will my buddies proboat ShockWave 26 esc went up in smoke today. It got the same esc as the widowmaker 22
Diesel6401
07-24-2010, 09:04 PM
Yup same motor/esc in both boats. I would swap out that esc out with a different one. What size motor is that (like a 540 "s" or "l" or something different? I would throw a seaking 90 or 120 amp esc in that boat and maybe a ammo 2600 on 3s would be a nice sport setup right around 28K on the rpm. Not sure that hull can take too much more power with its stability issues JMO
INTERGRATING
07-25-2010, 03:58 PM
I have a widowmaker, I threw in a 3c1p and smoked the esc, I now have a swordfish 120, but the hull can not handle the power, it is a waste of time to try and get this boat to preform anymore than it allready does outa the box.
