View Full Version : Full Flex Shaft
Diegoboy
10-21-2007, 12:59 PM
I pulled the stock shaft, drilled out the outdrive, Installed a brass bushing, Installed the Teflon liner, Installed the .130 flex shaft with a 3/16 stub shaft. I didn't stop there...
I pulled the motor, radio, & ESC, Installed the Ammo motor 2300kV (as opposed to 1500-1606kV stock), CC Baracuda 125, Novak XXL & an X645 prop.
Yes, I know the steering linkage isn't attached!:laugh:
webdr
10-21-2007, 02:05 PM
Nice. Did you run that prop on the stock motor/esc?
Diegoboy
10-21-2007, 02:36 PM
Thank you!
No. I never ran the stock power plant. It's up for salein the swap shop... FYI
Spoolin
10-21-2007, 02:46 PM
how fast are you trying to make that puppy go?
looks nice
Diegoboy
10-21-2007, 02:52 PM
looks nice
As fast as my funds will let me.
Spoolin
10-21-2007, 09:26 PM
i want to see some vid
10-22-2007, 06:51 AM
Why pull the stock power so soon?
Diegoboy
10-22-2007, 08:27 AM
Only because I know the Ammo motor well, and I know it'll perform better. Plus the stock power system is more desirable when it's New!
10-22-2007, 09:26 AM
Good point!! But I would have given the esc a beating. It looks pretty robust. But we all know looks can be deceiving.
lancel
07-18-2008, 09:31 PM
Diegoboy - I made several runs today adjusting COG and after about 5 minutes the U-Joint/Coupler gave out (pin is gone and one of the holding knuckes is snapped off. Rather than replace it with stock, I am keen to know where you purchased those Flexshaft components as I'd like this not to happen again and the flexshaft seems the way to go.
