View Full Version : Rio 51 conversion
Brushless01
07-21-2010, 03:36 PM
Im thinking about converting my rio to electric how fast do you think iot will go with this stuff ??
http://www.offshoreelectrics.com/proddetail.php?prod=ls-63outrunner&cat=135
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=10332
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10480&Product_Name=Turnigy_5000mAh_6S_25C_Long_Lipo_Pack
4 of those packs for 12s2p ?? and what prop
forescott
07-21-2010, 07:07 PM
You can search the forum for username "Doby" He has done this conversion already and its pretty impressive. He has some video as well. If I can find it I'll post the link.
forescott
07-21-2010, 07:12 PM
Here is some info. http://forums.offshoreelectrics.com/showthread.php?t=4569&highlight=brushless+rio
forescott
07-21-2010, 07:17 PM
Here is a video of it taking flight.
qTc0Uw2QI5g
Brushless01
07-22-2010, 01:48 AM
Dobys boats very nice but i dont have that kinda money to spend do would the setup i was thinking of work ??
forescott
07-22-2010, 09:08 PM
I dont know much about the monster 200, but I think you're combo is a good economical choice!
forescott
07-22-2010, 09:11 PM
12s puts you're unloaded rpm's just under 29000. Thats right where you wanna be. Whats the max amp rating on that motor??
Brushless01
07-23-2010, 01:56 AM
It doesnt say what about a collet ??
forescott
07-23-2010, 08:27 PM
What is the motor shaft diameter? I'm pretty sure the rio 51 uses 1/4 inch flex cable. I hope its not the one with the square end. OSE might have what you need. If not contact Jeff Wohlt @ rcraceboat.com. He can make you something for sure.
Brushless01
07-25-2010, 03:35 AM
The motors 8mm
forescott
07-25-2010, 10:33 AM
How about this one.....http://www.offshoreelectrics.com/proddetail.php?prod=oct-ocfhe8mm25
Brushless01
07-25-2010, 04:06 PM
Thanks !! how could i wire the monster to have two batteries in series and 2 in paralel im going to use ec5 connectors
Brushless01
07-26-2010, 02:32 AM
What about a mount ??
forescott
07-26-2010, 06:32 PM
I think the rio 51 has 5" spacing on the rails. Check out http://southriverrcboats.com/shop/catalog/browse?shop_param=shop_overview_pager%3D2%26cid%3D 16%26 They have a bunch of rail mounts for brushless motors.
Brushless55
07-27-2010, 12:20 AM
I'm going to tag along with this thread..
I will be getting in the mail a Rio 51z this week
Brushless01
07-27-2010, 02:58 PM
Brushless are you going to convert yours ??
Brushless55
07-27-2010, 06:42 PM
That's a great question 01 :confused2:
I love the runtime and sound of these 2 strokes
but the cool factor of brushless has me thinking :biggrin:
I would love to try a cheap KB45 700kv motor on 10s
Jacked1
07-27-2010, 09:32 PM
What size prop are you thinking??
Brushless55
07-27-2010, 11:33 PM
I have no idea, this is a big boat :confused2:
Brushless01
07-28-2010, 03:22 AM
x455 or x655 ?? The little screamers cant turn props over 60 mm
Jacked1
07-28-2010, 08:53 AM
I am trying to think of what gear ratio to use in 47inch mono, i know i am going to gear down a kb45 10xl 1200kv and it should be at about 15500rpm with a prather 275 (74.9mm and 4.3in pitch) and with pitch and diameter calculations the motor should see about as much work as a graupner 45-48mm in direct drive witch i am hopping won't break anything. After it is geared down at the prop will be around 705kv so i was very interested. All i need to do is seal the hatch and it is ready so i will let you know how it runs! I am getting all the bugs out with the kb45 then i am going to put dual 600 heli motors that are rated for a little more power than one kb45 and have them go to one outdrive. i have never seen it done in a boat this big (unless they were inline gassers) so i am pretty excited to see how it does.
I'm currently running one of these;
http://www.offshoreelectrics.com/proddetail.php?prod=oct-x470%2F3
Jacked1
07-28-2010, 10:38 AM
That looks nice! hmmmm And yours on 10s is around the same rpm as i am going for. Do you know how many amps you are pulling? I know that big 3080 has can handle a lot more than a kb45 so i might be in trouble with how i have it now.
My 3080 is a 12 turn, rated at around 490 KV if I remember correctly.
Never checked the amps.
Jacked1
07-28-2010, 11:25 AM
Thanks! I think it will be okay for now untill i get the other motors. I am gonna put up a build thread for it pretty soon!
Jacked1
07-30-2010, 12:21 AM
And here is the thread i was talking about, i mentioned your boat too in it doby! I would say it is kind of a hero for mine to look up to!:beerchug:
http://forums.offshoreelectrics.com/showthread.php?t=16689
Brushless55
07-30-2010, 01:15 PM
I think I will stick with gas on mine for the runtimes :beerchug:
forescott
07-30-2010, 03:19 PM
Let us know how she runs with that zenoah motor. I've been thinking about getting another big gas boat and the new rio is at the top of my list.
Brushless55
07-30-2010, 09:05 PM
I will buddy :beerchug:
I really would love to find a different muffler for it to get a bit more power out of the G260PUM motor
20-25min runtimes should be a hoot :laugh:
I'm going to break in the motor sometime this Saturday :rockon2:
Brushless01
08-01-2010, 04:54 AM
The problem is for me were i run i cant use a gas boat so i cant drive it anywhere except the sea which made the exhaust rust and i had to buy a new one its just ruiining the boat. Time to go to the best power source !! :cool2::thumbup::rockon2::beerchug:
forescott
08-01-2010, 11:58 AM
Same for me. I had a shockwave 55 that I really liked, but the fisherman where I ran really hated it. So I ended up getting rid of it. Now that I have a little more f.e. experience under my belt, I'd like to do a larger scale brushless build.
Brushless01
08-01-2010, 04:15 PM
Same its also kinda choppy most the time so the supervee is upside down the whole time. I think the Rio would be a great base for an Fe boat.
Rumdog
08-01-2010, 06:22 PM
You don't have to go that big to have a boat that stays right side up in the chop. The SV is a Very unstble hull at speed. It needs to be driven well to stay right side up, even on glass. There are a lot of smaller scale hulls that will do well in a bit of chop.
forescott
08-02-2010, 12:06 AM
You can get the older version of the rio 51 fairly cheap now that the updated version is out. I like the hull design. I know there are other boats that are smaller and probably will handle better. I just like "wow" factor of a big hull.
Brushless01
08-02-2010, 03:10 AM
Im getting a Delta force 29 knock off that I hope will handle the chop a lot better.
Brushless55
08-02-2010, 01:04 PM
I had mine out yesterday and WOW! :w00t:
not fast righ now but like you, I love the wow factor of this big hull
and it handled very well, turns are awesome!
and you can run this big sucker in some big shop :thumbup:
Chilli
08-02-2010, 03:42 PM
Try a CC racing Powermaster Pipe. They are a little pricey but the one I have runs great on my stock Zen. They are made out of aluminum and the two inch band gives the motor a wider power band which makes it a bit easier to tune. Great for a gas newbie like myself.
http://www.cc-racingengines.com/index.php?page=shop.product_details&flypage=flypage_images.tpl&product_id=95&category_id=6&option=com_virtuemart&Itemid=53&vmcchk=1&Itemid=53
Brushless55
08-02-2010, 05:16 PM
do I just need to put a hole in the back of the boat to exit the exhaust?
Chilli
08-02-2010, 06:17 PM
You can cut a hole in the transom or cut out the cowling, or do a little of both. It depends on how far the motor is mounted from the transom and whether or not you mind running the pipe on the outside. On my Sniper, the transom is just too small to run the pipe under the cowling. Mounting the pipe on the outside keeps the air under the cowl cooler and allows a header with less bends which will give you more power. But those that do not race may think the pipe looks butt ugly. I got used to it. LOL
Brushless55
08-02-2010, 06:29 PM
That does look kinda cool..
I would rather have the pipe hid under the cowl
forescott
08-02-2010, 06:53 PM
How does it sound with the stock exaust?? Fairly quiet?
Brushless55
08-02-2010, 09:32 PM
it sounds like a very strong weed wacker :rockon2:
I ran it rich on the HS and 10:1 oil mix
Brushless01
08-10-2010, 04:18 AM
Back to FE what mount would work with the little screamers ??
