View Full Version : Twin out-board cat discussion
F1 madness
07-19-2010, 01:32 PM
just want to get peoples opinion on this,im thinking of building a twin out-board Cat,this will be designed and scratch built by myself this is what iv come with:
hull 40"long x 13"wide x6"high to keep a low sleek looking hull.
(1/4 marine grade ply & 2mm,3mm Lite-ply)
2 x OS outboard legs
2 x Scorpion 4025,1100kv,6s,2200watts,100amp
2 x 200amp ESC
2 x metal geared hi-torque servo,running twin links to each Ob and linked together
2 x 47mm 3 blade props L/R
4 x 5000,30C+,3s.2 running in parallel to each motor
What you reckon,iv started drawing it up and hopeing to start build shortly LOL
F1 madness
07-19-2010, 01:33 PM
This is what im aiming for
Hull:
http://i577.photobucket.com/albums/ss219/retic79/F1%20boats/MONO%20RC%20BOATS/Rc%20offshore%20catamarans/dualcat.jpg
OS leg:
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/Osleg.jpg
Scorpion HK4025,1100kv:
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/Hk40251100kv.jpg
F1 madness
07-19-2010, 04:27 PM
Doing abit more research LOL
what about this set up:
2 x Scorpion 4025,890kv,8s,2700watts,95amp
2 x 200amp ESC
2 x 51mm 2 blade props L/R
4 x 5000,30C+,4s.2 running in parallel to each motor
which option do you think would be better
ozzie-crawl
07-19-2010, 04:34 PM
hey daz,have you looked at the REK lowers,not as nice looking as the OS but composite so both would probably weigh less than one OS, probably cost less to buy 2 reks than one os as well.
just a thought as there would be a lot of weight in the a$$ end
lol just looked at the size 40", should be ok with that power having a bit of weight,check prop size as most legs are limited to prop with the cav plate on
F1 madness
07-19-2010, 04:46 PM
Alrite bud
i have looked at the rek legs,but with the size of the hull and weight,just thought they be abit stronger.
im either not gonna run cav plate or will make a spacer for it as it screws on so not to worried about that part.
i will also install water pick ups in the sponsons,so wont matter if i run with or without :thumbup:
steveo
07-19-2010, 09:38 PM
might want to use inrunner motors because of the wet location
Outrunners would be better since they would shed any water more easily than an inrunner trapping the water inside the can.
F1 madness
07-20-2010, 04:34 AM
Cheers bud,but will be running outrunners,i know a couple others who run outrunners on outboards with no trouble.
ozzie-crawl
07-20-2010, 05:40 AM
yea out runners are great on tunnels,bit of a spray with wd40 at the end of the day to flush them out and there done
F1 madness
07-20-2010, 06:03 AM
sorted,which option do you think would be best buddy,you always give sound advice and i trust you:thumbup:
ozzie-crawl
07-20-2010, 06:16 AM
first of dont listen to my dribble,its a lot safer :blah::blah:
i tend towards high volts lower amps if it can be done. just check that the scorpion motors in the larger sizes bolt patten will fit the standard adapter on the lower leg (25mm) also the motor shaft needs to be 5mm i think as the square ended flex couplers are for 5mm shafts
i would look at twin cats around the same size and see what power there using
as in watts,shoot for some thing similar.
i think 6s with twins would be nice,hopefully doby mite chime in as i think he had a fair size scorpion in a cat,he may have more idea on there power out put and if a out board would handle the power
F1 madness
07-20-2010, 08:10 AM
Already checked bud: 5mm shaft,25mm hole spacing,thats why i chose these
http://www.scorpionsystem.com/files/i1,199_full_dimension.pdf
I have looked at a couple,but most seem to run singles,but did find this
http://www.rcgroups.com/forums/showthread.php?t=1043673
ozzie-crawl
07-20-2010, 08:16 AM
i havent looked at the big scorps for awhile couldnt remember.
i remember that blue cat,still got pics on my computer of it.
mite be worth sending the guy a pm
ozzie-crawl
07-20-2010, 08:20 AM
for got to add he is a member on here and knows his stuff
F1 madness
might do that actually,see your full of bright ideas:doh:
F1 madness
07-20-2010, 08:30 AM
most of my good ideas are in the off topic section (skippies and kiwis)
check the last 3-4 pages youll see what i mean :banana:
ill have a butchers now:thumbup1:
K.R.Joye
07-20-2010, 09:39 AM
I think outrunners would do great on O/Bs.They are so hard to cool(properly) inside a boat Couple of things, i would suggest using counter rotating motors just to offset the torque moment givin off by the outrunners also run 3/16 cables. Last, your going to need some good 150-200 amp ESCs, meaning don't go with Hi-Models. Etti 150s should do the job for 6S. Keep us posted!
F1 madness
07-20-2010, 09:59 AM
Thanks bud,so you reckon go with the 1100 kv on 6s,should be able to modify the out boards for 3/16 flexis.
Also what do you reckon to the overall size.
K.R.Joye
07-20-2010, 10:28 AM
Thing is you can run big props with outrunners, I would say maybe up to a 450 with 4025/1100s. You maybe be ok with .150 cable considering you will probably be running count/rotating motors with 447R&Ls.
A 40" Cat hull should handle the 2P weight, besides you will need the ballast to keep from flipping backwards on starts.
F1 madness
07-20-2010, 10:44 AM
Sorted im just starting the drawings now for parts needed to start putting it together,i think this is gonna be a fun and interesting build,and my biggest 1 yet LOL
will keep you posted on progress :thumbup:
07-20-2010, 11:40 AM
I run a Scorpion 4025/6 on 6S and it needs a lot more prop than an x447, even in a single motor 35" cat application. I know you want to run counter-rotating props, but you won't like the low speed from the x447s. Mine runs well on an x455, but if you want more than 45-50 mph you'll need either more pitch or more motor.
These motors are rated by Scorpion at 100 amps tops. I've run mine in the 130s and it doesn't get too hot, and in an OB application it may work okay. But remember that these motors are designed to run in an open helicopter and drawing over 100 amps continuous may shorten their life - or not.
F1 madness
07-20-2010, 12:43 PM
[QUOTE=Fluid;208671]I run a Scorpion 4025/6 on 6S and it needs a lot more prop than an x447, even in a single motor 35" cat application. I know you want to run counter-rotating props, but you won't like the low speed from the x447s. Mine runs well on an x455, but if you want more than 45-50 mph you'll need either more pitch or more motor.
Cheers bud,which motors and props would you go for then if i wanted hit min 50mph
BakedMopar
07-20-2010, 12:49 PM
I am not familiar with the O.S. lower unit but the K&B stub shaft doesn't allow for props with larger hubs (447's and up). Is there a way to lengthen the stub?
Edit sorry I meant OS lower unit.
F1 madness
07-20-2010, 01:14 PM
not sure,if i cant get that size prop on the stub that come with the unit ill have some machined at my local engineers,whose a friend of mine,nothing is impossible
BakedMopar
07-20-2010, 01:38 PM
Don't take it the wrong way. I was asking cause I would like to run a bigger prop on mine. I'm sure anything is possible if you have the resources.
F1 madness
07-20-2010, 01:53 PM
not taken wrong way,whats the biggest prop you can get on the standard shaft.
(how long is the hub is the max)
BakedMopar
07-20-2010, 02:34 PM
I can only get a 445 on. The 447 and up has a longer hub and I can't get the whole nut on. Not too sure inexact measurements but I can gt them for you later if you need.
F1 madness
07-20-2010, 02:38 PM
that would be a big help cheers bud,iv got some cf props the 42mm,45mm,47mm, all have the same length hub LOL
Darin Jordan
07-20-2010, 03:45 PM
If you replace the stub shaft assembly with one from Hyperformance Products, you'll have plenty of length, and a stub that will last a LOT longer than the standard K&B:
http://hyperprod.bizhosting.com/psa35.html
Cool project.... I'm going to be doing a dual outboard conversion on a ProBoat Miss Geico later this summer, but I'll be using dual ProBoat Stiletto Outboards on it with dual BlackJack or Stiletto power systems... Should be a fun project!
BakedMopar
07-20-2010, 03:54 PM
Thank you very much for the info Darin! I use my outboard on my rescue boat and I would love to use a 447/3 on it.
Darin Jordan
07-20-2010, 04:00 PM
No problem... that stub has about 1/4" or so more length. 447 should fit without any trouble.
F1 madness
07-20-2010, 04:53 PM
Alrite Darin,i look forward to seeing your version with awesome looking outboards,and the geico.
Im looking forward to start the actual build,but for now its just working all the measurments out,im pretty sure i can get it to look very simular to the 1 in the pic,but with my own touches (hopefully LOL)
Will keep posting with updates maybe even a few pics once drawn up.
DPeterson
07-20-2010, 05:32 PM
Awsome guy's. Looking forward to more pictures of dual outboard cats. Here's mine for some inspiration. Ran it this past weekend. I have a lot of work to do. All it did was porpuse. Could not get it on plane. When I hit the throttle it wanted to flip sideways. Probably will have to convert to counter rotation. I think too I had it way over propped.
29796
29797
29798
29799
F1 madness
07-20-2010, 05:37 PM
29796
29797
29798
29799
Man thats cool,what outboards you using on that they look ace.
Hope you get it sorted be sure to get a couple of vids,be interesting to see it go
Darin Jordan
07-20-2010, 05:39 PM
29796
29797
29798
29799
Doug,
On an OPC, when you raise up the outboards, it actually causes the nose of the boat to raise up (loosens up the front of the boat).
Might need to play with the outboard height. I'd keep the neutral, but adjust the prop depth and see if lowering it helps.
How does it balance out, by the way? Got any shots of the inside?
Eodman
07-20-2010, 06:11 PM
Yup raise the height on the transom not the angle or tilt from the transom! Is that a toysport jolly if it is did it come with the extra part in the tunnel? Mr Toth came up with the part to help with the porpoising!
Eodman
07-20-2010, 06:13 PM
If you go on Aqua Crafts site and look at their EP1 outboard - they have a pdf of the owners manual and in it - it shows a good starting spot for placement of the outboard on a transom!
Eodman
07-20-2010, 06:26 PM
I'm using the Hi-Performance 3.5 lower leg kit that Steven sells here on his site and I picked up a couple of 1700 kv brushless out runners from South River RC to try. These motors are the red ones on his site and if I remember right were $39 bucks a piece! So if it doesn't work I'm not out alot of money!
F1 madness
07-21-2010, 04:17 AM
I wanted to use these legs (bullet drive),but was having difficulty finding dimentions needed,so settled for the OS leg.
F1 madness
07-21-2010, 01:12 PM
Heres a quick drawing of the outline of the hull,side on view,all i got to do now is draw up the all the parts then get some board and start transfering it to that.
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/DSC00025-1.jpg
F1 madness
07-21-2010, 04:35 PM
LOL do you reckon a pair of these would work:
http://i577.photobucket.com/albums/ss219/retic79/Miscellanious/bigboy.jpg
Just kidding
DPeterson
07-21-2010, 07:44 PM
F1 Madness
The outboards are KMB gear drives. Went with these cause I had them and I was looking for extreme scale.
Darin
I built it without the adjustable plates as I only had one of them. Critical mistake I think. CG is close to 30%.
Eodam
Yes the Toysport Jollycat. Never seen a better quality built hull. What is this extra part you speak of? Thanks for advice on the auquacraft site.
I am going to focus first on getting one the outboards set up for counter rotation. Then see what happens. Will probably order another jack plate.
Doug
ozzie-crawl
07-21-2010, 09:11 PM
think he means the tunnel extension
F1 madness
07-22-2010, 05:15 AM
Well hopefully,i may have some new outboard legs to try,completely new not even on the market,but if all goes well they maybe,they should be more suitable for big power brushless motors 3/16 flexi and stubshaft,and be able to run upto 60mm props with cavitation plate tith water pick up,they have 12* angle change and 12mm height adjustment,will accept any motor with hole spacing up to 30mm.once i have 1 will post some pics,these will hopefully be available in cast alloy,or carbon poly.
Will keep you posted
Eodman
07-22-2010, 08:20 PM
do a search for eodman oanmd then jolly magic part! yes it is the extension!
Rumdog
07-22-2010, 09:21 PM
Definately make the drives counter rotating. If not, It will torque over to the starboard side extremely bad.
F1 madness
07-25-2010, 04:32 PM
yeah they will be counter rotating,will try it bothways to see which is best and more stable.
Going to pick up some boards on tuesday so i can start the build,should be a fun 1 thats for sure
timjz
07-25-2010, 05:26 PM
29796
29797
29798
29799
That looks really cool, how long is that hull? How do you like the geared lowers? Any inside shots?
F1 madness
07-29-2010, 10:20 AM
just got back from picking up some more materials to start the build,so gotta carry on drawing out the bulkheads etc and start cutting them all out.
Im really looking forward to this 1:bounce:
