View Full Version : connectors pk 4mm
xxxrems38xxx
07-17-2010, 06:51 AM
hi guys,
what do you think about pk 4mm for esc 180A turnigy and two lipo 3s 20-30c in serie or single lipo 6s?
forescott
07-17-2010, 10:59 AM
5mm bullits minimum. I use 6.5's between the motor and esc. what motor??
xxxrems38xxx
07-17-2010, 02:53 PM
i use the proboat A3630-1500:rockon2: of course for the 4s the pk 4mm are good??
forescott
07-17-2010, 10:47 PM
You're probably ok on the proboat motor. If you were running a larger castle/neu I would use 5mm+ for sure.
xxxrems38xxx
07-19-2010, 06:27 AM
and the deans are best compared pk 4mm?
forescott
07-19-2010, 05:50 PM
Deans are ok for low amp setups. I quit using them a while back. They are more difficult to solder than bullets. I would use 4mm bullets over deans.
ray schrauwen
07-19-2010, 07:51 PM
These are really nice and far better than the bannana style 4mm. Just in case you pull more amps, these will take it and are lower in resistance than bannana 4mm types.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130362211936&ssPageName=STRK:MEWAX:IT
I hate run of the mill bannana 4mm connectors, crap.
