View Full Version : 12xl or 13xl
xxxrems38xxx
07-15-2010, 05:20 PM
hi guys,
12xl or 13xl for the fastech? i've got no idea for a new motor! i want a motor more stronger than stock motor for run in 4s :help:
Diesel6401
07-15-2010, 05:42 PM
12xl on 4s is only approx 21,000 rpm and a 13xl is only around 19,800 rpm that's not alot of rpm. If you wanna run 4s try more like a 8xl or even a 9xl. Or set the motor timing on your fastech to high and run 5s stock.
forescott
07-15-2010, 09:49 PM
I'd go with Diesel's suggestion of the 9xl. Although You're stock proboat motor is a strong proven motor with a 4-pole design that creates more torque than a comparable feigao. I like the 5s suggestion!
Diesel6401
07-15-2010, 10:11 PM
I think its a 6 pole :thumbup: and strong/prove is dead on. Run 5s on it :thumbup1:
xxxrems38xxx
07-16-2010, 01:38 AM
ok but yet when i see video of similar boat of my fastech, for example the sv 27 with a motor 2300kv and 4s lipo i've got the impression it's more faster!
Diesel6401
07-16-2010, 01:57 AM
It prob is faster. 2300kv on 4s is 34,040 rpm(2300kv x 14.8v)
Your stock fastech is only 1500 or so kv on 4s thats only 22,200rpm. Your lacking rpm. Target range for rpm should be 28k-35k or soo. Your coming up short. Drop a 5s system in it and run 27,750rpm with the right prop it should scoot right along nicely. I would save my money and run 5s if I was you. I have a BJ same motor and if I don't sell it im running 5s on stock system screw paying for a motor. The motors you picked will not run very well 4s. If you want to run 4s your going to need to go with a higher kv. something in the 1800 to 2200kv range
Rpm = "kv" x voltage
xxxrems38xxx
07-16-2010, 02:19 AM
yeeaaahh thanks very much for advice Diesel!!!:buttrock: I couldn 't understand this history has kv voltage and you're my favorite teacher!:hug1: of course I want to stay in 4s which motor you advice me?
Diesel6401
07-16-2010, 03:04 AM
If im your favorite teacher your in deep :cursing:! lol
Depends on your price range really. If you want the more cost affordable route a fegiao 8xl or 9xl as listed before would suite you and maybe a octura x642 prop. I would lay-up and prob say a 9xl maybe better suited. I think I read somewhere that the proboat 1500kv motors are actually under-rated and are more like 1600kv or something like that. It's in the proboat section some where. Your gonna need a new speed controller with as well, your current which is 45amp I think, is not going to work. A seaking 120amp should work nicely.
http://www.kintecracing.com/Electrical.html
http://www.offshoreelectrics.com/proddetail.php?prod=fei-540XL&cat=116
If you want a more expensive set up
http://www.offshoreelectrics.com/proddetail.php?prod=cas-1518-series&cat=134
http://www.offshoreelectrics.com/proddetail.php?prod=cas-hydra240 or a seaking 180 found on kintecs page.
May I ask why you want to stay in the 4s range? Just curious. Happy boating...
I found what I was talking about.
Nope... the BJ motor tests around 1625-1650 actual KV. The SV27 around 1525-1550KV... I haven't tested this new one for actual KV, but it's a new wind, and should be 1800KV or more. I'll try to setup my test bench again one of these days to get the actual numbers... It's definitely a new motor wind. I had them annodize it and the ESC a different color so they'd be easier to differentiate.
electric - The internal dimensions of the battery tray (Width and Height) are 2 3/8" and 2 3/8". There is right at 1" between the bottom of the tray and the bottom of the ESC platform as well. A 2S pack or a 6-cell NiMH pack will slide up under there...
xxxrems38xxx
07-16-2010, 07:17 AM
ok thank you very much teacher!!!:thumbup: i want to stay in 4s because i 've got five lipo turnigy 5000mah 4s!!!!:roflol:
xxxrems38xxx
07-16-2010, 07:18 AM
oh!! I had forgotten the ammo 2300kv is it good for my boat?
Diesel6401
07-16-2010, 10:31 AM
It may be cheaper to buy some 2s and 3s packs then you can run 4s,5s or 6s for cheaper then buying esc/motor. Just an option.
It's an option. Im not a huge fan of that motor, but it will work on your boat plus it will work with your esc you already have. Need to run a smaller prop though, something in the 38mm - 40mm range that motor needs to wind out.
xxxrems38xxx
07-16-2010, 02:11 PM
ok my cousin got this motor i will try it with a grimracer 40/3 blades!
xxxrems38xxx
07-17-2010, 04:01 AM
first test this morning with the motor 2300kv ammo in 4s and grimracer 40 / 3 blades, that is just excellent! more speed and stability! of course at the end of the run the flex shaft is turning in thin air in the collet!! (sorry I used the translator on google! ;)) someone had a solution to fix my flexshaft? thanks
forescott
07-17-2010, 10:19 AM
The flex shaft is broken, or it came loose??
Diesel6401
07-17-2010, 10:35 AM
I wonder if the brass insert inside the collet got put in backwards when he changed motors. I've done the before :doh: lol
xxxrems38xxx
07-17-2010, 10:55 AM
it is still attached to the motor but it runs into space and the prop stops turning :confused2:
