View Full Version : Help whit aquacraft set up
carnalito
07-07-2010, 01:46 AM
I have a aquacraft sv 27 motor whit 60a esc, l try a pro boat resiver and transmitter that l have extra from another project and l cant make it work right it only works if l push the trigger forward, tried the buttons on top of the transmitter and make run backwards l have pull the trigger to make it stop do you know what l doing wrong??
Help please.
Brushless01
07-07-2010, 02:06 AM
The sv doesnt have reverse
carnalito
07-07-2010, 09:17 PM
l know lt will go forward if l push the trigger but l cant set it up so when l pull the trigger go forward, tried to change the two buttons in top of the transmitter but it only make it worse it will go by it self anr if l pull or push the trigger it will stop.
Any suggestions??
The transmitter and receiver are from a blackjack
Brushless01
08-01-2010, 05:00 AM
Maybe that radio isnt compatible with the sv27 esc and motor ??
scoota
08-01-2010, 05:36 AM
Try the thottle trim adjustment or try the throttle reverse switch on the transmitter ..does the tranmitter have to be calibrated with the ESC ???
