View Full Version : RIO Ep Propeller Shaft Size
petricek
07-04-2010, 04:28 PM
I just wonder if RIO Ep uses 3/16 or 1/8 propeller (shaft ). I want to replace stock with octura. Thanks.
Jesse J
07-04-2010, 07:39 PM
I'm pretty sure its 1/8" but you can shim with K&S tubing to use 3/16".
what setup are you running? be careful not to overload your system and burn up battery and/or ESC...
petricek
07-04-2010, 07:50 PM
I have for now Traxxas XL-5 with stock motor. I also have Traxxas Stinger 20 turn which I didn't tried yet. I already melted down 12 turn Titan because I run it with stock 42 mm propeller.
After I will fix all stock boat problems ( motor mount,battery holder and flimsy hull I will go brushless.
