View Full Version : WTB 1/8th x .125 flex cables (2)
Alexgar
07-02-2010, 03:06 PM
as stated above 5" or longer
Jeff Wohlt
07-02-2010, 03:34 PM
1/8" stub shafts to 125 cable?
Alexgar
07-02-2010, 03:48 PM
yes sir
Jeff Wohlt
07-02-2010, 04:01 PM
That is a close fit....very close. Not sure I can drill those but will try a sample. How long of stub? 2" or 2.25"
Alexgar
07-02-2010, 04:21 PM
got a cable thats about to quit on me and i need to get a cable for this hardware, ill used on my new cobra, Do you think it will work jeff
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=11983&Product_Name=Turnigy_Cobra_Fiberglass_V-Hull_385mm_(Hull_Only)
Alexgar
07-02-2010, 04:22 PM
2" should work
Alexgar
07-02-2010, 04:24 PM
fdm sells hugheys but if some one had a few laying around that be great
Are you sure? I run 1/8" stub shafts with .098 cable in my boats, easier to make.
It has been years since I have seen continuous diameter cables. Old way was to take a 1/8" flex cable, and cut the outer layer of strands off of the last 3/8". Then you measure the smaller inside cable and drill the 1/8" stub for that. solder it all together and polish the joint down to a continous diameter. We did this with 1/4" cable, but it should be the same.
Can't drill a 1/8 stub with a .125 hole, they are the extact same size! Go 1/8 stub with .093 wire.
Brian
Alexgar
07-02-2010, 04:31 PM
i had a 1/8 to .098 cant hold the power of a fiego L class motor they just break first or second time out
http://www.finedesignrc.com/hardware/125x125cable.jpg
bustitup
07-02-2010, 05:13 PM
I may have what u need....I will let u know when I get home
Alexgar
07-02-2010, 06:56 PM
sorry i pm you i misunderstood your post send some pics to my yahoo
Alexgar
07-02-2010, 10:21 PM
home yet bustitup?
bustitup
07-03-2010, 11:27 AM
home yet bustitup?
sorry mine are 3/16" propshaft with .125 cable
sailr
07-03-2010, 11:33 AM
sounds like you need to convert to wire drive
Jeff Wohlt
07-03-2010, 05:31 PM
Yep, I can make you a 1/8 x 062 wire drive that will hold it.
Alexgar
07-03-2010, 08:46 PM
how much mr jeff for 2
Alexgar
07-03-2010, 08:47 PM
and 1 collet
