ggcrna
06-23-2010, 11:10 PM
Has anyone had this problem w/ the stock sv motor? :
So i overheated the motor a couple of times, and the glue that holds the end plate (shaft end) has let go. The motor still runs, but if I grasp the motor barrel and twist it , it rotates while the end plate stays in place (screwed onto motor mount). How did you fix it? Or did you even bother?
Thanks,
Glenn
Thanks,
Glenn
