View Full Version : Traxxas Titan 12 turn
petricek
06-21-2010, 06:34 PM
Hi guys, are you running traxxas 12 turn Titans in RIO Ep? I installed XL 5 and motor to my new Rio because stock ESC melted down on my second day running 7 cell 4600 mA Intellect pack. Well, slightly used Titan melted down completely in my first run on the same pack. It was hot day and the propeler got tangled up many times on pond's plants. I wonder if that could melt down my motor.I am new in rc boats, I am running rc cars.
Are those 12 turns and so motors too hot for boats? Are 19 turns and up better choice? It is big difference between Rc car and Rc boat BRUSHED motors? I will appreciate any information from those who know better. I am building another boat, 16 scale hydro. Thanks Peter.
forescott
06-21-2010, 08:02 PM
Hmmm.... I picked up a used rio ep with the same setup. xl-5 esc and titan 12 turn. I ran the 9.6 volt baterry a few times before mine burnt up.
petricek
06-21-2010, 08:52 PM
Do you mean ESC or motor burned up?
forescott
06-21-2010, 09:08 PM
the motor.
forescott
06-21-2010, 09:09 PM
Ive since replaced it with a graupner 8.4 race brushed motor, but its much slower.
BakedMopar
06-22-2010, 02:01 PM
The traxxas motors are hit or miss. Mostly miss. If you want to stay brushed look into a speed 600. It will drop right in.
Brushless55
06-22-2010, 02:27 PM
What about the esc and motor out of a ERevo?
would this work well?
petricek
06-22-2010, 03:00 PM
If you are changing a motor for different turns, does the propeller need to be change as well? I have feeling that motor turns to propeller ratio is the same as changing spur gear and pinion in rc car.
forescott
06-22-2010, 04:37 PM
I know the higher number of turns=more torque, but less rpm. I'm gonna get another 12-turn and use a smaller prop. I think the stock 42mm prop is too big anyway. The 12 turn is cheap enough that if I burn another one it wont be that big a deal. I wish I could use a real canister style motor cooler.
Jesse J
06-22-2010, 04:49 PM
How about a 23 turn Titan (http://www.offshoreelectrics.com/proddetail.php?prod=dh-1585)? OSE sells em for pretty cheap. As long as you don't overload em, they should work pretty good. I have burnt one up though, running 4S lipo through it on a 442 prop, so take it easy on the load and it should be ok. If you are looking for speed, you will eventually end up in the brushless world - not a whole lot more expensive, especially if you consider how many brushed motors it takes to accept the fact.
forescott
06-22-2010, 05:08 PM
Im not sure if this motor will get much speed on my 9.6v nimh. Maybe a 3s or 4s lipo.
petricek
06-22-2010, 06:09 PM
I have just bought 20 turn Traxxas Stinger. I will see how that will end up. Have to look into that propeller thing more. I know that 12 turn Titan is rated around 9.6 V or so . 9.6 is limit for XL-5 anyway. And yes, I agree that brusless is way to go but it is expensive to buy it off the bat.
I like those cooling jackets sort of plastic sleeve that embraces whole motor. Offshore sells them. I will replace that cheapo Aquacraft motor mount so I can use it.
Diesel6401
06-23-2010, 03:35 PM
I use to run a xl-5 with a titan 12t on the stock 42mm prop. I ran with a 7 cell, best I could get was 18mph. Then I put the stock motor back in and made a rescue boat out of the rio which worked for a while now I have a apache 24 rescue boat. Much better.
diesel, what was the black stuff you had on the pvc for your rescue boat?
Diesel6401
07-28-2010, 11:12 PM
Insulation foam. Should be in the same aisle of the pvc pipe at home depot. Its added for floatation and help not to strach the boat being rescued all up. The rescue rig takes about 30ms and under $15, great investment.
forescott
07-28-2010, 11:43 PM
Be sure to get the stuff that isnt cut down the middle. Home depot has both kinds. It slips snugly over 1/2 inch pvc.
Diesel6401
07-29-2010, 01:19 AM
I bought the stuff with the cut down the middle, all I did was zip-tie them to the pvc and face the open end up towards the sky. Works for me, although the other one u suggested maybe easier.
forescott
07-29-2010, 01:53 AM
I almost bought the same, but found the closed end stuff on accident. you gotta work it a bit to get it on, but it comes out really nice!
Diesel6401
07-29-2010, 03:17 PM
I started a thread to maybe help and answer so questions: http://forums.offshoreelectrics.com/showthread.php?t=16705
forescott
07-31-2010, 08:53 PM
I got another traxxas 12-turn and ran it with the 535 prop on 2s lipo. Was expecting more speed than my graupner race 8.4. But no-go! The speed was about the same and the motor ran waay hotter. It will only be a matter of time before I burn up another 12-turn and put the graupner back in. Oh well, The 12-turn only cost me 20-bucks shipped!
forescott
07-31-2010, 08:58 PM
I'm thinking of running the 23 turn traxxas motor from the villian. Got the idea from jesse j. I have a small 3300mah 4s lipo and an extra seaking 60a esc. to use, so I would only have to purchase the motor. Plus I have the y535 prop I,ve been playing around with. This might be a good combo??
Diesel6401
07-31-2010, 09:08 PM
I think I read somewhere that Grim ran this motor http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJ766&P=7 stock prop on 2s for low 20s. Let me see if I can find that link.
*Edit Found the post*
vspec..
your post is honest and well done..
The Rio EP was not designed to be a speed demon.. If that was the case it would have been brushless.
The market for this boat is the new guy that just wants to get the feel for an RC boat and the 2.4 is hobby shop friendly.. do ya know what I mean?
Anywho.. YEP.. its time to MAKE IT ROCK.. mine has went 22 on a brush (Speed 600) motor and 7 cells..
Lets have some fun………
Grimracer CHALLENGE to the go fast guys……..Go ahead.. knock it off the top!
ROCK ON!
Grim
Disclaimer: Modifying you boat will void the warranty.. but I bet you knew that!
